Results 1 to 9 of 9
Thread: Varnamo EV-5 shaper
12th Feb 2021, 05:39 PM #1New Member
- Feb 2021
- Poland
- 4
Varnamo EV-5 shaper
Good morning Guys,
I'm a new on this forum. I need some help with my shaper Varnamo EV-5. I bought this machine and when I start it the clutch break doesn't work - the arm is moving all the time, no matter in which position is the clutch lever. I took out the pulley and the clutch from the shaft. I took apart it, clean it and assembled it, but it doesn't work. Maybe some of you have a manual for this machine, because I can not find it on the internet. I'm not sure if the clutch is complete, maybe there is some missing parts. Please help me.
Tomas
12th Feb 2021, 06:04 PM #2
Hi Tomas,
Welcome to the forum.
It seems that everybody wants money for a copy of the manual for that machine !
Maybe some pictures of the clutch would help.Best Regards:
12th Feb 2021, 07:24 PM #3Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
Welcome to the Forum
It looks like Lathes UK might have a manual https://store.lathes.co.uk/varnamoAll The Best steran50 Stewart
12th Feb 2021, 08:29 PM #4Golden Member
- Oct 2001
- ACT
- 667
there is this thread not sure of how much use. does have one diagram at bottom of this page https://metalworkforums.com/f65/t170...rebuild/page-3
12th Feb 2021, 09:25 PM #5Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
This is all I could find.
Varnamo_Ev_Shaper_Manual.pdf
12th Feb 2021, 10:00 PM #6New Member
- Feb 2021
- Poland
- 4
Thank you Techo1 for document what you got. I will try to translate it and see what it can be.
Next issue is that, when i move clutch lever towards the machine or backwards there is no "click" that something was clutched. I think normally it should be some sound of engaged or disengaged the clutch
15th Feb 2021, 01:53 PM #7Member
- May 2009
- 75
I have a Swedish neighbour if you want some specific paragraph translated. I wouldn't ask her to do much (unless you want to pay her), I don't know her that well, but I'm sure she'd be happy to roughly do some critical paragraph. Assuming it's Swedish - Google Translate couldn't make sense of a single word.
Lots of links out there - some of those folks might be able to help. Just like this forum, if you contact people they can be extremely helpful. They're different EV models but the one manual seems to cover them all so they must be almost identical. Also, note there seems to be a lot of results with mis-spellings, eg "Varnarmo" and "Varnamo".
https://www.practicalmachinist.com/v...ebuild-249785/
https://www.practicalmachinist.com/v...ern-pa-362089/
https://www.youtube.com/watch?v=f-4AeaqIxb8
Phil
EDIT: translates ok at Google Translate as Swedish when you type it in, eg Page 10: "Nr 1 lamellkoppling ar utford enligt ovanstaende skiss, och det erforderliga trycket pa lamellen astadkommes genom att en ring av hardade stalkulor tvingas ned i ett kilformat spar under det forskjutbara kopplingshuvudet (1), varvid de bada brickorna (2) tryckes samman fran sidor mot lamellskivan (3)" becomes "No. 1 lamella coupling is challenged according to the above sketch, and the required pressure on the lamella is achieved by forcing a ring of hardened steel balls into a wedge-shaped groove under the displaceable coupling head (1), the two washers (2) being pressed together from the sides against the lamella plate (3)".
15th Feb 2021, 04:49 PM #8New Member
- Feb 2021
- Poland
- 4
Thanks for advise I will try contact them.
15th Feb 2021, 04:51 PM #9New Member
- Feb 2021
- Poland
- 4
varnamo
Shaper, 18" Macson (Alba) shaper Brisbane
By pedro54 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 9th Jul 2019, 12:02 PM -
A Shaper thought from a non-shaper owner
By Michael G in forum METALWORK GENERALReplies: 5Last Post: 25th Dec 2018, 04:15 PM -
Varnamo EV-3 Shaper Rebuild
By Brobdingnagian in forum METALWORK GENERALReplies: 44Last Post: 17th May 2013, 11:53 AM -
Varnamo Shaper
By RayG in forum METALWORK GENERALReplies: 170Last Post: 21st Jun 2012, 01:53 AM
