Results 1 to 10 of 10
Thread: Part off tool size
8th Feb 2021, 01:09 PM #1Senior Member
- Nov 2012
- Mid North Coast NSW
- 422
Part off tool size
Do you own one of these ?
I'm trying to find out what the cutting height is. Not much point contacting the seller about it cos the language barrier is huge.
Cut-Off Sets SL195-16 with TiN coated Inserts_Cutting Tools_M&G Productions
8th Feb 2021, 03:00 PM #2Most Valued Member
- Sep 2010
- Lebrina
- 1,910
I'm fairly certain that it is a 19mm cutting height based on the number of the holder - SLTBN 19-05. If you google that number, numerous manufacturers come up with the specs.
8th Feb 2021, 04:48 PM #3Senior Member
- Nov 2012
- 422
8th Feb 2021, 07:26 PM #4Gear expert in training
- 34
- 1,075
You can simply mill 3mm off the bottom of the holder to make it 16mm
8th Feb 2021, 08:58 PM #5
The number on the blade suggests a 26 mm width and 2 and 3 mm wide inserts.Best Regards:
8th Feb 2021, 09:01 PM #6Member
- Sep 2010
- Port Sorell, Tasmania
- 74
9th Feb 2021, 11:41 AM #7Senior Member
- Nov 2012
- 422
12th Feb 2021, 06:26 PM #8Senior Member
- Nov 2012
- 422
Don't know what M&G is up to now.
They have 2 email addresses. On Monday I sent a query to both addresses about the product and haven't heard back (5 days later).
Now Vic's going into a hard lockdown and I may not be able to buy anything from them.
12th Feb 2021, 08:47 PM #9Most Valued Member
- Sep 2010
- Lebrina
- 1,910
15th Feb 2021, 08:59 PM #10Member
- May 2009
- 75
And don't ever leave negative feedback on an auction site for them (even if they screw you over) or they will telephone you and abuse you. I still buy stuff from them but it's largely rubbish. I buy stuff when I know I can either fix it or it's not critical. Just got an ER35 D1-4 collet chuck today, in fact. The cams are badly machined and needed heaps of filing to get them to lock correctly. Once through that fun the runout was actually pretty good, about 20 microns, fine for what I want to use it for.
Hercus 260 quick change tool post and tool size
By Shaun@27 in forum THE HERCUS AREAReplies: 13Last Post: 24th Apr 2021, 10:45 AM -
wanted quick change tool post 250.202 size
By Gravel in forum WANTED TO BUYReplies: 0Last Post: 30th Jan 2019, 06:26 PM -
Hercus 260 Quick Change Tool Post size
By localele in forum THE HERCUS AREAReplies: 8Last Post: 31st Oct 2015, 05:43 PM -
(now working) Which tool - lathe or mill to make this part?
By Ridgy in forum METALWORK GENERALReplies: 12Last Post: 5th Jan 2011, 12:55 AM -
4-way tool post, part missing?
By neksmerj in forum THE HERCUS AREAReplies: 17Last Post: 8th Dec 2008, 08:19 PM
