Results 1 to 15 of 23
8th Feb 2021, 11:29 AM #1Novice
- Feb 2021
- UK
- 11
Advise for tempering a BBQ from stainless
Hello.
My mate is a sheet metal worker and built me a lovely BBQ last year from my specs.
he made it from 3mm stainless.
The BBQ buckled and warped after a few uses.
He’s about to make me another, half the size of this one, and I want to avoid the warping.
I’m guessing the warping was because the steel was soft and not treated.
Can anyone please advise on how I can prevent the same happening again.
My mate has no facility/possibility to heat treat the steel at his work place.
Here is a pic of the previous BBQ before being used.
Dave
8th Feb 2021, 11:57 AM #2Senior Member
- Apr 2018
- 168
Its not tempering or anything else you can do to stop stainless buckling. Stainless is a poor conductor of heat so with a fire in centre , most of heat will stay there and stainless will expand while outsides will not.
Stainless may look good but it is a bugger to work with sometimes.
How about reusing the one you have but cut out the bottom leaving a 25mm lip around base. Then use another piece of thicker stainless or even mild steel to sit inside. That way the inner section can expand but outside frame will not.
8th Feb 2021, 12:22 PM #3Member: Blue and white apron brigade
Yea I would use a box-inside-a box design.
Inside box using 3mm sitting inside an inside box of 1 or 1.6mm should do it.
8th Feb 2021, 01:13 PM #4Novice
- Feb 2021
- UK
- 11
Thanks for both of your replies.
the new BBQ he is making me is for camping, so needs to be made from scratch.
is there a better material to use than stainless?
8th Feb 2021, 03:19 PM #5Golden Member
- Mar 2009
- 54
- 825
G'day Dave,
You could stick with the original box design as done previously and make a second layer from expanded mesh with short legs to sit inside the main box. The expanded mash should absorb most of the expansion differential with minimal buckling. Another advantage of expanded mesh is you can use heavier gauge without adding significantly to the weight and it will allow your fire to breath better.
You can also go with plain mild steel mesh if you don't mind the rust.
Greg.
8th Feb 2021, 06:22 PM #6Philomath in training
When I was active in scouting, all the BBQ's we used were plain steel. Better conduction than stainless (so not as potential to warp). The grease/ oil from the food being cooked usually was enough to protect the steel parts from rusting (In other words, don't clean it too well).
8th Feb 2021, 07:08 PM #7Member: Blue and white apron brigade
For camping we used a SS clothes dryer drum as a fire pit and a removable 6mm mild steel plate for the cook top.
the Stainless is very think <`1mm
A second drum could be placed on top to act as an oven like this
We cooked bread, Pizza, slo roasts, scone etc in that oven but never a sign of buckling.
Eventually we decided it took up too much room and switched to a flat packable thing like this - its just mild steel.
The are heaps of similar flat pack deigns out there
I do have 6mm thick SS and MS hotplate top for it.
SWMBO made up a tough canvass bag for it and it takes up much less room in the van.
It doesn't seem to rust that much and any parts that do seem to get burn off in the subsequence use
8th Feb 2021, 08:34 PM #8Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
I made my outdoor fire pit from 3mm Mild steel plate. I heat a 30sq metre outdoor area with it to the point of too hot, and it hasn’t warped yet.
8th Feb 2021, 08:53 PM #9Novice
- Feb 2021
- UK
- 11
Thanks again for everyone’s suggestions.
I want to keep my design if possible, as it suits our style of cooking, and I already have a grill, skewers, and grill baskets that will fit it perfectly. Also, I like having the charcoals directly under my food in most cases.
how about aluminium?
8th Feb 2021, 08:56 PM #10Novice
- Feb 2021
- UK
- 11
8th Feb 2021, 08:56 PM #11Philomath in training
Aluminium might work, but the trouble is that if the fire gets hot enough it could anneal, so go soft on you.
8th Feb 2021, 08:59 PM #12Novice
- Feb 2021
- UK
- 11
8th Feb 2021, 09:21 PM #13Most Valued Member
- Mar 2011
- 1,555
It will eventually burn through
8th Feb 2021, 09:45 PM #14Novice
- Feb 2021
- UK
- 11
I’ll be really grateful if anyone can come up with a solution that enables me to keep my original design.
Gregs idea was good, but I move my charcoals about during cooking, and the expanded mesh would make that hard.
Dave
9th Feb 2021, 12:09 AM #15Novice
- Feb 2021
- UK
- 11
Would the box be less likely to warp if it was built/welded from separate base and sides, rather than being bent from a single sheet?
I need adVISE
By phaser in forum METALWORK GENERALReplies: 7Last Post: 23rd Jun 2020, 03:21 PM -
Looking for tool advise
By Lagair in forum METALWORK GENERALReplies: 8Last Post: 6th Aug 2018, 09:23 PM -
Very first TIG welds. please advise
By Zumanity in forum WELDINGReplies: 5Last Post: 9th May 2014, 03:28 PM -
advise need please
By boyblueeye in forum WELDINGReplies: 8Last Post: 13th May 2012, 12:22 AM -
Powdercoating advise
By Geoff Dean in forum METALWORK GENERALReplies: 7Last Post: 26th Jan 2006, 11:03 PM
