Results 1 to 14 of 14
Thread: Source for long BSF screws?
7th Feb 2021, 04:51 PM #1Member
- May 2009
- 75
Any idea who might carry 1/4" x 26 BSF countersunk screws, 3" long? Tried a few of my usual sources without any luck. Thought I'd ask before I resort to making them. I hate making small diameter screws, especially long ones. Holding them is a PITA, lots of turning around and adjusting stickout. I need 10 of them, too.
Phil.
7th Feb 2021, 05:57 PM #2Golden Member
- Dec 2011
- 505
These people in Parramatta have helped me out with odd/obsolete sizes: Lee Bros. Engineering Supplies
Their website does not give much detail, probably best to phone.
Best of luck,
Bill
7th Feb 2021, 06:19 PM #3Member
- May 2009
- 75
7th Feb 2021, 06:20 PM #4Philomath in training
- 6,541
Another one to try -
https://www.classicfasteners.com.au/
7th Feb 2021, 06:33 PM #5Member
- May 2009
- 75
Thanks Michael. I did try them. Nothing on their website that matches and no response to an email.
7th Feb 2021, 07:12 PM #6Diamond Member
- N.W.Tasmania
- 1,407
Nuts and Bolts in Tasmania are great too. Sadly they closed my local store but the remaining two branch stores have friendly and knowledgeable staff and a huge range of stock at good prices. Details below
No affiliation, just a happy customer.
Nuts & Bolts Tasmania
101 Albert Rd,
Moonah, Tas, 7009
7th Feb 2021, 07:38 PM #7Golden Member
- Dec 2011
- 505
Best of luck,
Bill
7th Feb 2021, 09:03 PM #8Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
Newcastle High Tensile Bolt Co have 1/4x3 Hex listed but not countersunk
8th Feb 2021, 01:03 AM #9Senior Member
- Sep 2007
- Country West Oz
- 77
- 169
I needed some longer than 2 inch and 2 inch was the longest I could find so I made them from 2.5 inch hex head bolts.
I locked a couple of nuts together on the thread to hold it in the chuck and turned the head down to a countersunk head, then cut the slot with a slitting saw.
I needed 48 of them so I made about 55 just in case. The whole exercise didn't take long once I got set up to mass produce them.Regards
Bradford
8th Feb 2021, 04:54 AM #10Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 312
Classic Fasteners https://www.classicfasteners.com.au/..._Catalogue.pdf have a 1/4 BSF x 3" hex bolt. A bit of machining and you will have a countersunk head.
8th Feb 2021, 09:56 AM #11Member
- May 2009
- 75
Thank you, Snapey, I didn't see the hex head 3" bolts, I'll have a look.
Thank you Bradford for the machining tips. Good synergy with the previous posts. I'll have a think on that one.
8th Feb 2021, 03:03 PM #12Member
- May 2009
- 75
Thanks again, everyone. Lee Bros in Parramatta and Nuts and Bolts in Tasmania couldn't help. I bought some hex bolts from Classic Fasteners and I'll have a crack at machining the heads. If that fails, I'll have to make them.
In case anyone is interested, these hold together an Eclipse mag chuck I've just about finished restoring. I had to drill a few out, they'd rusted under the countersinks due (I believe) to coolant ingress.
Phil
8th Feb 2021, 09:06 PM #13Senior Member
- May 2019
- 77
- 312
Phil, If you haven't got the machines to convert these hex bolts to countersunk then you're welcome to use mine if you're familiar with a centre lathe and turret mill.
Better still ... I'll machine them for you but you'll have to hook up a wiring loom on my 7 clubman. My God I'm hoping you're an auto electrician.
8th Feb 2021, 09:59 PM #14Member
- May 2009
- 75
Thanks, Snapey, but I've a 12x36 lathe, an SX-4 mill and a grinder, so if I can't machine them I deserve to donate them all to a good cause. But I don't have a $*&^%*#$ 1/4" 5C collet and have just ordered one. Ach!
And you wouldn't want me to touch your clubman. I've been driving around in a Jeep with a bad connection on the EGR sensor for 10 years. If I did your wiring you'd try to start the engine and your toaster would turn on.
Phil
Source needed for long 3/8 - 20 tpi BSF bolts or allthread
By caskwarrior in forum METALWORK GENERALReplies: 8Last Post: 9th May 2018, 02:01 PM -
eBay- how long is too long to wait?
By jack620 in forum METALWORK GENERALReplies: 20Last Post: 17th Dec 2012, 08:38 PM -
reconditioning a windmill (long long story here)
By .RC. in forum METALWORK GENERALReplies: 35Last Post: 29th Sep 2012, 07:14 PM -
Chicargo Screws source
By wheelinround in forum METALWORK GENERALReplies: 5Last Post: 14th Feb 2012, 06:32 PM -
Help with finding screws
By ElDubya in forum METALWORK GENERALReplies: 9Last Post: 9th Mar 2009, 09:01 PM
