Results 1 to 3 of 3
Thread: Useful gadet for the mill.
7th Feb 2021, 02:37 AM #1I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
I was just watching for some random reason a mrpete video on Youtube. Don't know why, as I usually find his videos rather tedious, but this time paid off, as he used a gadget called a Rose Index.
May have been posted here before, I don't know, but anyway...
It's obviously not a workholding solution, but what it does allow you to do is quickly index round (and probably other shaped) things (via use of a square from the bed to the index) that won't work in a collet block for one reason or another and need to be held in a vice. Rather expensive to buy, but of course if you have a rotary table you can knock one up in whatever size you desire very quickly. You can do it without a rotary table too, just rather more tedious involving either angle plates if you have them, or a painful combination of trigonometry and indicators.
The other advantage of making your own is being able to configure it however you like. Personally I'd consider changing the square section to a decagon, as you can get 90 degree increments out of the octagon, and 5 sided collet blocks aren't that common, probably because there's not often a call for them (I think I have seen one once though). Only catch with that is it would need to be a decent size unit you were making in order to get a decent length on the reference face. If it's a smaller one, maybe a pentagon would be a better bet. Then again, for the time it'd take to knock one out on a rotary table, you could make a couple of different ones...
Yet another item on the roundtoit list - there have certainly been occasions when this thing would have been very useful for me (especially previous to having a Joe 12 sided collet block).
7th Feb 2021, 09:29 AM #2Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
That certainly looks like a very handy gadget and not just for a Mill either, it could be used in a drill press too. I didn't watch MrPete's video for the same reason as you, but I did watch this simple clip which basically shows how useful the Rose Index is https://www.youtube.com/watch?v=ljs1kp-9bgM . Thanks for sharing.
All The Best steran50 Stewart
7th Feb 2021, 10:52 AM #3
Hercus o mill Vertical mill head lubrication
By china eyes in forum THE HERCUS AREAReplies: 0Last Post: 14th Oct 2018, 06:57 AM -
Selecting a small Mill / Mill/Drill
By Wombat200 in forum METALWORK GENERALReplies: 31Last Post: 15th Mar 2012, 10:58 PM -
Arboga EM825 mill vs Hercus model 0 mill?
By neksmerj in forum METALWORK GENERALReplies: 23Last Post: 14th May 2011, 03:16 PM -
Face Mill V End Mill
By eskimo in forum METALWORK GENERALReplies: 8Last Post: 31st Aug 2010, 03:19 AM -
