Results 1 to 7 of 7
Thread: Circuit breaker!
5th Feb 2021, 05:52 AM #1Senior Member
- Jan 2012
- 149
Circuit breaker!
Bit of a worry:
Inside a fake un-trippable circuit breaker. - YouTube
5th Feb 2021, 07:40 PM #2
I only buy from reputable Australian electrical store sellers, but this shows how sometimes you can get caught out
Using Tapatalk
5th Feb 2021, 07:57 PM #3
That's why you buy your electrical gear through a reputable elec wholesaler rather than direct from China or via ebay.
Not putting the poo on DIY electric people, but if you want to do it, at least use products from reputable brands and suppliers that actually do have a significant investment in product and reputation that they need to protect to stay in business. I recall the Chinese cable scam from 10 years ago when lots of sparkies and DIYer's went outside their normal supply lines to buy Chinese sourced cable that was embossed as being to standard but had dodgy insulation that deteriorated within 10 years, so lots of houses needed a full rewire once the stuff started breaking down. If I recall, the Importer/distributor disappeared very quickly when the issue became known.I used to be an engineer, I'm not an engineer any more, but on the really good days I can remember when I was.
5th Feb 2021, 08:04 PM #4
Did you hear a reputable company had a counterfeit batch come through unknowingly?
Using Tapatalk
6th Feb 2021, 09:44 AM #5Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
I don't claim to be an expert in this field (or probably any field come to that) but my understanding is that electrical products for general sale in Australia have to be submitted to an Australian authority for testing and approval.
Once the approval number is granted there are no spot checks by the authority that the spec of the approved item is maintained.
Unscrupulous makers know this and submit 'sample quality' specimens to the authority after which they start supplying the identical in external appearance rubbish they always intended to supply.
There were a number of solar panel related house fires in Queensland which were traced back to dodgy isolators which had come onto the market via the above route.
As usual if you are buying directly from the usual overseas suspects you are on your own.
8th Feb 2021, 09:26 AM #6Most Valued Member
- 4,258
Not sure that they are tested here in Australia, but rather approved on the basis that they have certified testing results....which can be easily falsified.
We have seen approval given to bigger international companies, then most of these small fry fly by nighters in China, only to get caught later
Volkswagen comes to mind.... VW
not saying they carried out their certified testing tho..lol
8th Feb 2021, 03:36 PM #7Pink 10EE owner
- 6,218
Plenty of dodgy stuff out there these days.
I have a cheap stick welder. One a large supplier of cheap stuff sells. I ran it flatout 4mm rods after 4mm rods and started to melt the plastic front panel off and the thermal cut out has still not clicked in.Gold, the colour of choice for the discerning person.
Chip Breaker for the Diamond Tool Holder?
By topari in forum METALWORK GENERALReplies: 8Last Post: 9th Jul 2018, 06:54 AM -
Failing incandescent bulb trips circuit breaker
By bob ward in forum GENERAL DISCUSSION / OFF TOPICReplies: 1Last Post: 4th May 2016, 08:27 AM -
VICTORIA Powerbuilt Sockets, Ratchet, Breaker bar, 3/4"
By TermiMonster in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 6th May 2012, 09:14 PM -
Circuit Breaker- How Many Amp's?
By DirtPig in forum WELDINGReplies: 9Last Post: 26th Jul 2011, 12:32 AM -
200 amp arc welder (newb) why is my breaker always fliping?
By iceman423 in forum WELDINGReplies: 10Last Post: 28th May 2009, 09:26 PM
