Results 16 to 30 of 31
  1. #16
    Sep 2008
    Riddells Creek, Vic.
    836
  2. #17
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by SurfinNev View Post
    It will be a 13mm four flute end mill (which I have now)
    Since you have the end mill and you're prepared to sacrifice it, you might be able to bore a hole in the end with a cheap 6mm solid carbide end mill. Then Loctite a 6mm diameter pin into the hole in the end mill.
  3. #18
    34
    1,079
    If you or anyone else can drill and tap a 4mm thread in an endmill then i sure would be keen to know how to do it, a spark eroder could do the hole, but the thread.......
    Carbide threadmill would probably do the job. It might not last long with HSS. Only catch is you need a CNC mill...
    EDM/spark tapping is a thing that exists, but that needs even more fancy machinery
  4. #19
    Apr 2018
    168
    The hinges are only a hard plastic. What about a step drill or make a similar tool to suit the hole you need.
  5. #20
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,104
    What's wrong with using a tool made for this exact purpose?
    e.g. https://www.ebay.com.au/itm/293622208439
    They are available in just about any size combination....
    Cheers, Joe
  6. #21
    34
    1,079
    That's way too practical and boring
  7. #22
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,513
    Because there is not a size I need.
    Nev.
  8. #23
    34
    1,079
    Is 1/2" close enough to 13mm to work? You can probably turn down the pilot to whatever you need with a carbide tip
  9. #24
    Nov 2008
    70
    1,513
    Quote Originally Posted by Sparksy View Post
    Step drills do not come with a 6mm to 13mm step in one step. Wouldn't work anyway, as I need a flat seat for the nutsert.
    Nev.
  10. #25
    Nov 2008
    70
    1,513
    It's done. Used a carbide burr in the centre hole on end of 13mm end mill to open it up a bit and roughen the surface. Super strength Araldite was used to bond the pilot piece into the end. Experimented on a hinge I bought and it works very well. Thought the end mill would grab and tear a large hole in the hinge but that did not happen. Used end mill in a cordless drill with the clutch on minimum. Who said I couldn't do it.
    Nev.
  11. #26
    Nov 2008
    70
    1,513
    Will be doing the gates on Sunday. So just 32 more holes to counterbore and 32 nutserts to install. Will file this tool away after this job just in case I need it again.
    Nev.
  12. #27
    Apr 2012
    Healesville
    2,129
    Good one Nev, it is good to succeed..... but it is FANTASTIC when you are told that you cant do it and you did
  13. #28
    Nov 2008
    70
    1,513
    Trouble is sometimes I get carried away and occasionally try something that fails miserably. You are right though, feels great when a plan works. Took a fair amount of time though to get there.
    Nev.
  14. #29
    Aug 2019
    Revesby - Sydney Australia
    57
    1,195
    As far as I'm aware 13 mm isn't a standard end mill size.
    1/2" in a wobbly chuck?
  15. #30
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    What about Interchangeable Pilot Counter Bores https://www.ausee.com.au/shop/item.aspx?itemid=4143 . They come with a 4mm Pilot, but the nearest Counter Bore is a smidge bigger than what you want at 13.5mm .
    All The Best steran50 Stewart
  1. Narrow slots - Woodruff ? Slottting Endmill ? Other ?
    Last Post: 17th Sep 2017, 08:37 AM
  2. I need some 1mm endmill any one here have them ?
    By thorens in forum METALWORK GENERAL
    Last Post: 6th Aug 2014, 10:57 AM
  3. endmill sharpening
    Last Post: 4th Aug 2013, 10:59 PM
  4. Useful endmill rpm chart
    Last Post: 6th Oct 2011, 10:29 PM
  5. $530 endmill
    By Greg Q in forum METALWORK GENERAL
    Last Post: 24th Jun 2011, 09:19 PM
