Results 1 to 10 of 10
Thread: Purchasing milling cutters
1st Feb 2021, 08:08 AM #1Senior Member
- Nov 2012
- Mid North Coast NSW
- 422
Looking for recommendations, where to buy Tungsten end mills (and other milling cutters) in Australia ?
Tungsten is so damned expensive. I'm particularly interested in cutters larger than 12mm, like 16 and 20mm 4 flute.
1st Feb 2021, 10:09 AM #2Most Valued Member
- Jul 2016
- 35
- 1,522
Id just contact a rep for a manufacturer like guhring, sutton, iscar etc and either ask them directly or get them to reccomend a supplier. When I buy new I usually try for new old stock off ebay first and failing that just buy from a rep.
1st Feb 2021, 04:57 PM #3
I avoid using large solid carbide cutters bigger than 12mm because of the expense.... I do use carbide insert endmills in larger sizes. I find that more economical given my propensity to chip things....
I find the quality of M&G very acceptable:
Cutting Tools_M&G ProductionsCheers, Joe
1st Feb 2021, 06:48 PM #4Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
Toolprocure sell DHF solid carbide endmills, which are quite well priced and work very well. But you would be looking at over $200 for a 20mm.
At work we use indexible endmills for anyting over 12mm, works out much cheaper.
1st Feb 2021, 08:13 PM #5Gear expert in training
- 34
- 1,075
+1 for inserts, big carbide = $$$
2nd Feb 2021, 07:41 AM #6Most Valued Member
- 2,651
I recently bought a 14mm insert endmill from Banggood just to give it a try.
I haven’t been a fan of the cheap generic BAP400 style face mills ex eBay etc but love my Kennametal 63mm facemill.
I was pleasantly surprised with how the Banggood insert tool performed and their “blue nano” inserts.
As others have said - inserts are much cheaper to run than solid carbide for larger tools and will be the direction I head going forward for larger end mills.
For smaller carbide end mills I’ve found the Magpro (M&G) ones good for my use - but I haven’t had any proper branded ones to compare with so YMMV.
2nd Feb 2021, 10:22 AM #7Senior Member
- Nov 2012
- 422
Lots of votes for indexable end mills I see.
I haven't tried them but would have thought indexable as a harsh interrupted cut compared to spiral cutters which tend to peel away the metal.
Anyway, my round column mill might be a bit shaky to use them.
2nd Feb 2021, 10:30 AM #8Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
I have a 20mm and a 16mm insert end mill that I use where ever possible. They have their limitations but they are cheap to run, they use the APKT etc inserts.
2nd Feb 2021, 05:48 PM #9Gear expert in training
- 34
- 1,075
The nicer ones use an APKT style insert, which has positive rake in all directions and cuts very well.
Solid carbide is still unbeatable for finishing cuts where you need to use the full length of the tool, but for general material removal and facing cuts, these indexables are the way to go.
7th Feb 2021, 02:20 PM #10Member
- May 2009
- 75
Another vote for indexable end mills, and you can even buy HSS inserts. AJ Warner in the USA makes HSS inserts at reasonable prices.
https://www.arwarnerco.com/
https://littlemachineshop.com/info/inserts.php
https://www.amazon.com/s?k=Warner+HSS&ref=nb_sb_noss_2
I'm always surprised nobody seems to be aware of these. Great for brass or when you want either a super-sharp insert or a big nose radius, or even want to grind a profile for some weird job. Also, their HSS blanks are excellent quality. Harder to get shipped from Amazon, just use a shipping service.
Phil
Face milling cutters
By Alf Scotting in forum METALWORK GENERALReplies: 2Last Post: 1st Dec 2018, 08:48 PM -
Indexible milling cutters
By morrisman in forum METALWORK GENERALReplies: 11Last Post: 6th Aug 2015, 09:08 AM -
Cutters for milling machine
By woodfast in forum METALWORK GENERALReplies: 18Last Post: 10th Apr 2012, 05:05 PM -
Holders for milling cutters
By Tiger in forum METALWORK GENERALReplies: 4Last Post: 11th Oct 2009, 02:13 PM -
I'm after some odd milling cutters
By funkychicken in forum METALWORK GENERALReplies: 10Last Post: 4th Sep 2009, 09:28 PM
