Results 16 to 26 of 26
Thread: Broken cast bracket
30th Jan 2021, 10:36 PM #16Golden Member
- Vic
- 48
- 544
Hi Matt, I have had some luck brazing castiron in the past. Also "nickel" electrode with arc welder, I also tried TIG using nickel electrode as filler (remove the flux). I would think Braze would be the best to fix your broken part.
30th Jan 2021, 11:26 PM #17Diamond Member
- N.W.Tasmania
- 1,407
Karl, my welding skills would best be described as rudimentary, but my gut instinct would be to braze this part with silicon bronze as first choice in any repair operation. Next would probably be nickel electrodes if I could just purchase a few from a local welding service. A well known YouTube content creator, Brian Block repaired a large radial arm drill which he dropped after the rope on his newly installed, but second hand crane snapped. If I recall, he just used low hydrogen rods and possibly peened the weld runs as he laid them down, I'm not sure now, I may be remembering that technique being used by boilermakers at one of my old work places. Is that the approach that you would take if using low hydrogen rods? (Pre heat and slow cooling taken as a given.)
At that same workplace, Eutectic 680s were a go to rod for people doing stuff at home on very basic home welders, especially those that only had a high and a low setting. They were easy to strike and got a good hold on most metals people wanted to weld. I doubt that the 680s would have been as popular if the users had to pay for them themselves though;-)
31st Jan 2021, 12:15 AM #18Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
31st Jan 2021, 12:33 AM #19Most Valued Member
- Sep 2010
- Lebrina
- 1,915
I don't know about proving any particular point, I was more interested in why you chose stainless electrodes for the job given their cost and also the assumption that you would most likely have other electrode types at your disposal as most people do.
Stainless electrodes have gained something of a cult status when it comes to "difficult" jobs which is in many cases misguided.
In no way am I trying to convert you from your favourite remedy, I only sought to clarify the point that they were neither neccessary, nor recommended.
31st Jan 2021, 12:49 AM #20Most Valued Member
- Sep 2010
- Lebrina
- 1,915
I haven't done a great deal with silicon bronze and the TIG, but it seems quite a popular method. Based on what I have in my personal arsenal, I would go with Eutectic Xuper 2240 electrodes if I were stick welding the job or castcraft nickel electrodes with the flux knocked off if I were using the TIG. Both these methods will produce a deposit that can be machined, drilled or filed as required, which is of prime importance on this job. Honestly, oxy brazing would be a viable option too.
While preheating is rarely a bad thing, it assumes lesser importance when welding a broken piece back on to a casting that is not subject to restraint as the component is free to move during the inevitable heating and cooling of any form of brazing or welding. As you mentioned, peening can assist greatly with minimising distortion and stress build up. I like to use an air chisel with the chisel ground to a radius rather than a chisel point, although a ball pein or chipping hammer works really well for occasional use. Slow cooling is less important if the job can move (expand and contract) freely, but obviously never quench the weld, which is bad practice anyway.
31st Jan 2021, 09:11 AM #21Most Valued Member
- Healesville
- 2,129
Karl the point that i made was that i would have this particular cast welding job finished and back on the machine with no fuss with a simple arc welder, and a grinder for the edge prep.
There is no drilling or machining required, this particular job would have to be the simplest and most straight forward you could get.
I would say in 5 minutes i would be sitting down having a cup of tea while the job cools.
This job is not rocket science and anybody that can run an arc could do it successfully with a stainless, or if they wanted castcraft rod.
My advice to other metal workers is to actualy have a go at welding cast, get some experience and dont be put off by fears and complexities spread by pro welders.....
31st Jan 2021, 11:18 AM #22Gear expert in training
- 34
- 1,079
I have some recently-out-of-date (still works fine, we just can't use it anymore because aerospace) aerospace glue sachets if you want to try simply sticking it back together.
This stuff is made as an alternative to welding and they literally build planes with it; we've used it at work to fix broken castings before if they're not going to be under a huge load.
https://www.clickbond.com/product-de...sive-cartridge
31st Jan 2021, 07:56 PM #23
31st Jan 2021, 11:20 PM #24
Let's know how you go, please.
However, cast iron was a choice of material made at the time out of necessity, not functionality.
It is a bad choice in the context of an adjusting screw opposite the break. It should nave been cast from malleable iron or made from steel - even back then.
I would strongly suggest (in the absence of a milling machine) to fabricate it out of 3 mild steel flat pieces with full thickness welds. Whatever method you choose to repair the broken bit with, is NOT going to have the strength of the original cast iron part. And you can clearly see that wasn't sufficient...Cheers, Joe
1st Feb 2021, 08:26 AM #25Most Valued Member
- Healesville
- 2,129
Yes a stronger part could be made but the part must have been strong enough to last all these years.
You dont think over tightening the bolt might have had something to do with it breaking?
1st Feb 2021, 11:44 AM #26Golden Member
- Mar 2009
- 54
- 825
Just be aware that when using adhesives on cast iron they will be absorbed into the grain and can cause problems if you decide to braze or weld the part down the track.
Greg.
Mandrel bracket
By phaser in forum WELDINGReplies: 8Last Post: 4th Jul 2019, 10:08 AM -
Broken Cast Iron. I need help.
By steck in forum WELDINGReplies: 7Last Post: 10th Feb 2017, 11:59 PM -
Sword Bracket
By mick661 in forum METALWORK GENERALReplies: 6Last Post: 20th Oct 2016, 08:25 PM -
Broken cast aluminium
By jmk89 in forum METALWORK GENERALReplies: 8Last Post: 3rd Jul 2006, 06:05 PM -
Repair of Broken Cast Iron
By Grahame Collins in forum METALWORK GENERALReplies: 0Last Post: 11th Feb 2006, 11:35 PM
