Results 1 to 8 of 8
Thread: Removing rivets
    Nov 2007
    melbourne australia
    3,228
    Default Removing rivets
    I removed one of my security doors so I can replace the flyscreen mesh. The bloke who installed it used countersunk rivets instead of tek screws. After drilling the heads off the rivets I discovered there's timber inside the aluminium cladding of the door jamb. I expected it to be hollow and for the rivets to drop to the bottom. The shanks of the rivets are captured by the timber but free to rotate. So I can't drill them out and they can't drop down out of the way to allow me to fit screws or new rivets.
    Can anyone suggest how I might get the remaining bits of rivet out?
    Apr 2012
    Healesville
    2,129
    Chris I might be a bit rougher than you so i would use a pin punch and knock them in a bit further....
    Nov 2007
    melbourne australia
    3,228
    That might work John. It's Vic Ash, so it might require a big hammer! I'll give it a go.
    Aug 2007
    Saskatoon, Saskatchewan, Canada
    292
    I've never seen a hinge done like that before but since the pictures don't show any inlaying or notching for the hinge is there any reason you can't lift or lower the hinges half an inch or so to fresh metal?
    Pete
    Nov 2004
    Bungama SA
    52
    960
    Id take a sharp pin punch and deform center outwards enough to stop the spin, or collapse them inwards enough to push through.
    Its not a thermal break type aluminum frame is it?
    Dec 2013
    Sydney
    201
    Superglue the rivet and/or head in place, then drill out as usual.
    Graham.
    Nov 2007
    melbourne australia
    3,228
    Thanks gents. Some good ideas there. I’ll start with the glue trick and take it from there.
    The windows and doors are aluminium clad to meet the bushfire code.
    6,480
    Hi Chris,
    A squirt of supa glue ! Give it time to set and drill gently with a sharp drill.
    Edit: I really should read all the posts before replying !
  1. Tinmens rivets
    By node105 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 20th Jun 2017, 06:28 PM
  2. Tinmens rivets
    By node105 in forum METALWORK GENERAL
    Last Post: 19th May 2017, 09:54 PM
  3. Truck chassis rivets
    Last Post: 19th Sep 2015, 12:23 PM
  4. Rivets
    Last Post: 7th Dec 2012, 11:26 AM
  5. Rivets.
    By RETIRED in forum METALWORK GENERAL
    Last Post: 28th Jun 2008, 10:18 AM
