Results 1 to 15 of 15
Thread: Lathe Bed Protector thing....
25th Jan 2021, 10:29 PM #1Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I have a job where I need to fit the four jaw to my lathe ( Lathe Risers ) and I didn't have anything to rest the chucks on or to protect the bed.
I remember when I was in High School ,ALL the Lathes had these peices of timber which we were made to use, when chaging chucks. ( Don't know why?....what could go wrong?...lol )
So I thought I'd whip one up so I could use it this time AND have it on hand where I needed to do the swap again.
I assume everyone else already has one?...lol
( small victories....)
https://photos.app.goo.gl/EhT9YFm8eUXYrdnX9
https://photos.app.goo.gl/yE8jMksGrd8VF1aG6
26th Jan 2021, 01:16 AM #2Senior Member
- Jun 2020
- Freo
- 68
- 142
Gee that's very fancy. I just have a small cabinet door that a mate had made undersize. He's a woodchuck type person
26th Jan 2021, 02:35 AM #3I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,297
I've just been using a bit of 12mm MDF I've had hanging around for changing chucks on the AL335, but for those with bigger chucks on bigger machines, Joe Pieczynski on one of his Youtube videos showed his chuck changing setup. Don't remember which video exactly it was, but basically he has a big lump of wood with the profile of the ways cut in the underside, and a curved pocket in the top for the chuck to sit on. The chuck centreline sits a couple of mm below spindle centreline when resting on it, and he basically uses the block of wood as a sled to slide the chuck onto or off of the camlock pins.
Thought that was a pretty nice setup, unfortunately won't work at all on the Graziano, lol. Also think I need a bigger bit of MDF, and a bit of wood underneath to space it up over the way covers.... but that's a problem that's some way off yet.
*edit* Found the video, should start right at the bit where he shows the chuck sled off. If not, skip to 10:54 to see it. https://www.youtube.com/watch?v=edOt0gRH0Tk&t=652s
26th Jan 2021, 06:39 AM #4Philomath in training
I have one. I used to use it quite a lot on the old lathe when I had a screw on chuck. Now, with a camlock chuck and no sudden 'It's undone moment' not so much. It's just as likely to be used as a table surface if I'm doing maintenace on the lathe and need a flat surface near the bed to put things on.
(I did think about something shaped but I have several chucks of different sizes, so decided to save the space)
26th Jan 2021, 08:31 AM #5Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
With a camlock spindle, a wooden cradle is useful on a big lathe with heavy chucks.
The cradle can be machined to a chuck's outer diameter on the lathe itself, to about a semi-circle.
I think some method to allow it to slide but not move otherwise is needed for machining it.
Then the chuck can be placed upon it, and slid along the bed ways towards the spindle.
The height will be perfect so no further lifting is required.
That's how it was at a TAFE metalworking school.
26th Jan 2021, 08:52 AM #6Member: Blue and white apron brigade
Here's one that was in a monthly email that I got recently from Machinists Workshop.
My Hercus chucks are pretty light weight so I just put a piece of thick vinyl under the chucks on top of the bed.
26th Jan 2021, 09:05 AM #7Most Valued Member
I have one each for my Hercus 3 jaw and 4 jaw chucks. Similar design to the ones in Bob's post. Wedges are easier to make than a curved cradle, as you can just move the wedges until you get the chuck on centre height. Then secure them in place.
26th Jan 2021, 12:26 PM #8
Hi,
A "me too: for at least wooden 1 chuck saddle. Mine is a 1 only, for a 4 jaw which I made soon after acquiring my lathe.
Fourteen years later I think it is a good time to start work on a second one for the 3 jaw . I now have assorted hernias and a back problem, so I don't want to push my luck when I have to dismount the 3 jaw in favor of the heavier 4jaw.
I like the features of the Machinist Workshop model, locking out cross movement across the ways and the wedge cuts centralizing the chuck and aligning it with apparently minimal vertical movement required .
A reminder to self to paint the units with clear lacquer to minimise black greasy fingerprints.
Nice job!
26th Jan 2021, 02:42 PM #9Most Valued Member
pics for racingtadpole.
26th Jan 2021, 04:03 PM #10Golden Member
- Apr 2018
- Drouin Vic
- 634
The first machining resource I ever read- Sparrey's "The amateurs lathe" called this a chuck board and more or less said the world would end if you did not have one. I have one like Steve that lives on the foot end of my lathe and is home to my dividing head (yeah), oil cans, other homeless bits and bobs. I'm inspired by Steve's photo to put a runner under one side of it so it sits level.
Although I have a gantry for chuck changes, it does add a level of reassurance.
26th Jan 2021, 08:36 PM #11Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Some nice variations there.
I like the 'wedge' idea. Gives you a bit more security.
I saw the fancy 'half round' version on U tube. Very nice.
I change chucks about once every 400 years so I will see how mine goes. I can easily add some wedges if I deem it useful.
26th Jan 2021, 09:35 PM #12Senior Member
- Jun 2005
- Townsville, Tropical Nth Qld.
- 226
I use a plywood protector just in case, but I have a small block and tackle with a webbing sling to change my chucks as I don't want to risk damaging my back.
Sadly I have a few friends that have lower back damage and they are having a miserable retirement.
Rgds,
Crocy.
28th Jan 2021, 04:11 AM #13Senior Member
- Aug 2007
- 292
I use a board on the bed as an oops protector too but to hold and control the chucks when I slip them into position on the D1-5 spindle I use a dowel or bar. Before removing the chuck I slip a bowl/bar of steel/metal tube of about foot and a half or so long into the jaws and tighten them, halfway down on the dowel (old broomstick actually). Then I loosen the cams and with a rubber mallet in the left hand and gripping the end of the dowel with the right, give the chuck a tap to get it to let go. Now I can slide the chuck off until the pins clear and it drops slightly on to the dowel. With the dowel in the shaft I can slide it along until I can get my left hand on the dowel and then pick the chuck up with both hands. I leave the dowel in the chuck until next time I want to use it. I'm a klutz and have way more control when handling the chuck than when trying to move or lift it with just my hands. Saves the lathe bed and my toes.
Pete
28th Jan 2021, 05:44 PM #14Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
29th Jan 2021, 04:20 PM #15Senior Member
- Nov 2012
- Mid North Coast NSW
- 423
This is the way I change chucks. I have 4 for this lathe and esp the 8" is getting way too heavy now.
Mine are screw on so the 25mm steel pin rotates.
Underneath the lathe is a trolley for the 3 heaviest chucks. It rolls out right under the crane. The crane mast is bolted to the lathe bench leg.
Gotta deal with getting old somehow.
Lathe spindle nose protector !
By BaronJ in forum METALWORK GENERALReplies: 26Last Post: 16th Jan 2019, 09:49 PM -
A Simple Enhancement for a Screwed Spindle Nose Protector/Ejector
By Anorak Bob in forum METALWORK GENERALReplies: 2Last Post: 16th Jul 2018, 05:20 PM -
DIY lathe bed protector
By th62 in forum METALWORK GENERALReplies: 6Last Post: 5th Sep 2014, 12:25 PM -
lathe bed way protector.
By th62 in forum METALWORK GENERALReplies: 13Last Post: 15th Aug 2014, 08:51 AM -
This a good thing or a bad thing?
By Old Hutcho in forum METALWORK GENERALReplies: 17Last Post: 5th Jan 2014, 05:36 PM
