Results 1 to 4 of 4
Thread: Post Drill
23rd Jan 2021, 01:06 PM #1
Post Drill
I recused this post drill, and thought I would clean it up a bit.
Who made “The Globe” post drills?
23rd Jan 2021, 01:24 PM #2Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
Possibly Dawn?
23rd Jan 2021, 01:37 PM #3
I gave her a citric bath for a couple days and with a bit of gentle persuasion I managed to get most of the parts off, but how do I gets these parts off?
23rd Jan 2021, 05:09 PM #4
I too believe Dawn may be the manufacturer. I don't know if "Globe" is a Dawn brand, or whether Dawn manufactured them for Globe (or vis-versa).
The second picture is the Coupler that couples the Feed Screw to the Spindle. This needs to be disconnected first.
On my Dawn No.611 post drill there's a set screw on the left-hand side to release the feed screw. On my Canadian Blower & Forge No.61 post drill there's a fork at the bottom of the coupler to release the spindle.
I'm not familiar with Globe post drills, but now that you've removed the two set screws from the coupler, either the spindle will slide out the bottom (releasing the angled cog in the process), or you can wind out the feed screw. If it's the feed screw then you'll most likely have to wind it upwards and out - but if it has a non-threaded section at the bottom (inside the coupler) then you'll need to wind it downwards - which can be problematic as you'll likely run into the coupler/spindle before you have it all the way out.
If the spindle can be withdrawn downwards first, then the feed-screw and it's nut can be withdrawn downwards together.
It may be a case of partly withdraw the spindle (downwards) to give clearance to withdraw the feed screw and nut (also downwards) before pushing the spindle back up far enough to remove the square key that runs in the slot in the spindle, and then withdrawing the spindle all the way down.
Experiment until you work out the correct method for a Globe post drill.
Dawn coupler - post #28 https://www.woodworkforums.com/f163/...drill-148288/2
CB&F coupler - post #15 https://www.woodworkforums.com/f163/...ge-61-a-177652
Good luck, and please put up photos (for the next Globe new owner).
Cheers, Vann.Gatherer of rustyplanestools...
Paper drill from converted drill press
By bollie7 in forum METALWORK GENERALReplies: 4Last Post: 16th Mar 2020, 07:26 PM -
Restoration Projects - Tough Drill Press - Dawn Drill Press - Record Pipe Vice
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 10th Feb 2019, 03:11 PM -
Post Drill
By iRonsforge in forum THE SMITHYReplies: 13Last Post: 16th Jul 2014, 02:14 PM -
Drill Point Drill
By Penpal in forum METALWORK GENERALReplies: 11Last Post: 18th Jan 2007, 10:22 AM
