Results 16 to 26 of 26
Thread: DRO Recommendations
22nd Jan 2021, 07:29 PM #16
Hi Greg,
Thanks for that info ! It will be interesting to see how I get on with them. I didn't know about the length though.
I just measured the bed lengths, so it will be interesting to see how much they add for the read head. I wonder if they can be cut down like the magnetic scales. As far as drilling holes in the mill, I'm not overly fussed about that. Whoever gets the mill after me is welcome to it !
I'll post when I get mine and take some pictures.Best Regards:
25th Jan 2021, 10:08 AM #17Golden Member
- Dec 2007
- 574
Glass scales can be cut there are a few youtube videos showing how, mounting the scales does take some thought as they need to be adjustable in two planes to ensure alignment, the leads are easily shortened as long as you have a small soldering iron.
The calculator function is a bit clunky as you need to enter leading zeros and for me it is easier to just pickup a hand held calculator - the circle hole function is great for getting equal spaced holes set around a circumfrence, I had to do a dummy run through the process as the manual instructions are not that clear, I've also used the straight line hole function to drill a line of equally spaced holes when making amplifier turret boards.
I have a 2 axis DRO on the lathe and there are times I don't turn it on if precision is not required - on the mill though I only ever used the DRO now.
28th Jan 2021, 10:08 PM #18Best Regards:
29th Jan 2021, 12:34 AM #19Senior Member
- Jun 2020
- Freo
- 68
- 142
Has anybody used the Touch DRO setup. Am thinking of that with a 1 micron scale for X and a 5 micron for the Z on the new lathe
29th Jan 2021, 09:10 AM #20Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,553
29th Jan 2021, 01:31 PM #21Senior Member
- Jun 2020
- Freo
- 68
- 142
29th Jan 2021, 02:00 PM #22Most Valued Member
- Healesville
- 2,129
I know nothing about touch dro but I dont think those igauging scales are that accurate, also if you do need accuracy then you need a dro that you can adjust the linear compensation.
29th Jan 2021, 05:28 PM #23Senior Member
- Jun 2020
- Freo
- 68
- 142
29th Jan 2021, 06:51 PM #24Most Valued Member
- Healesville
- 2,129
Mike I just had a bit of read at the touchdro website and it looks good, linear compensation/calibration is an important part of the dro installation process that nobody seems to do but when you accurately measure the travels they are not correct out of the box.
https://www.touchdro.com/resources/g...libration.html
29th Jan 2021, 08:15 PM #25Senior Member
- Jun 2020
- Freo
- 68
- 142
30th Jan 2021, 07:01 PM #26Best Regards:
MIG Wire Recommendations
By what-da in forum WELDINGReplies: 2Last Post: 29th Jun 2019, 09:57 AM -
Mig welder recommendations
By snapatap in forum WELDINGReplies: 16Last Post: 2nd Dec 2018, 06:20 PM -
A new machine vice - recommendations
By bollie7 in forum METALWORK GENERALReplies: 46Last Post: 9th Sep 2018, 04:06 PM -
End Mill Recommendations
By 19brendan81 in forum METALWORK GENERALReplies: 5Last Post: 17th Aug 2018, 07:14 PM -
4 jaw chuck recommendations
By snowyskiesau in forum METALWORK GENERALReplies: 39Last Post: 7th Oct 2008, 06:11 PM
