Results 1 to 6 of 6
Thread: Gear train help
18th Jan 2021, 04:10 PM #1Member
- Aug 2019
- Nambour Queensland
- 63
- 86
Gear train help
Hi, is there a service provided that can help me with gear train calculations. Due to extremely high cost I intend on changing my coil winding machine over to metric off the shelf gears. As I don't have the 18 change gears supplied from new which are imperial I was hoping for a setup as the lathe gearing uses to convert thread cutting to metric on old lathes giving me a train that is the same as the gear legend on the machine. Thankyou.
18th Jan 2021, 05:39 PM #2Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
I thought imperial stock gears were fairly easy and cheap to get? what DP are your existing gears?
18th Jan 2021, 06:58 PM #3Member
- Aug 2019
- 63
- 86
18th Jan 2021, 09:57 PM #4Senior Member
- Oct 2015
- melbourne
- 473
If you only need a few perhaps you could find someone who could 3d print thrm
A guy in UK has started printing gears for old Drummond lathes, apparently work very well.
I would expect coil winding would be less load.
18th Jan 2021, 11:03 PM #5Member
- Aug 2019
- 63
- 86
18th Jan 2021, 11:49 PM #6Senior Member
- Feb 2014
- Werribee, Melbourne
- 177
I can do a sample for you - PM sent.
Myford Gear train
By wheelinround in forum METALWORK GENERALReplies: 10Last Post: 30th Apr 2013, 06:27 PM -
train video
By morrisman in forum METALWORK GENERALReplies: 6Last Post: 25th Nov 2012, 06:40 PM -
Ever seen a train lay its own track ????
By matthew_g in forum METALWORK GENERALReplies: 21Last Post: 22nd Jul 2012, 12:52 AM -
Gear train to cut imperial threads on metric lathe (AL 340)
By 19brendan81 in forum METALWORK GENERALReplies: 11Last Post: 17th Jan 2012, 03:15 PM -
Le Tournage - mise en train d'un tour Schäublin 102
By Anorak Bob in forum METALWORK GENERALReplies: 22Last Post: 19th May 2011, 03:01 AM
