Results 16 to 20 of 20
Thread: Dust masks
18th Jan 2021, 07:22 AM #16
3m versa-flo is the clear visor.
The PAPR welding helmet Speedglas G5-01 can be run as a clear visor if you remove the welding lens. ie pulls double duties, but pricey north of $2500.
18th Jan 2021, 07:23 AM #17Member: Blue and white apron brigade
5th Jun 2021, 08:12 AM #18Member
- Aug 2014
- North Queensland
- 86
Airshield Pro user
After reading about the Trend Airshield Pro mask I purchased one earlier this year. Searching the internet the best priced one I found was from VEK Tools for $510 approx, also purchased the ear muffs as an extra. Generally satisfied with it as a dust mask around the shed but as member mw460 noted it is a noticeable weight while using it but gives good ventilation without fogging up. Ventilation fan is a constant noise but acceptable. Two weeks ago I decided to wear this mask when I had some mowing with a zero turn mower on an area not lawn and uneven with fairly long dry grass. Usually mow these areas wearing tinted goggles and ear muffs but some times quite a bit of dust etc thrown up. Tried wearing a dust mask as well but gets too hot and uncomfortable. Well this didn't last too long as the bumpy ride and weight of helmet kept me having to adjust the helmet to its original position. An extra head harness strap may help keep it more secure. Apart from the glare from the sun I also felt some motion sickness starting. Maybe because wearing glasses as well meant the horizon was changing focus too much but I don't really know. I don't usually suffer from motion sickness. This was not what the Airshield Pro was designed for but I thought it worth a go. In hindsight a positive airflow helmet with a belt mounted battery making a lighter head weight would be better and still be ok in the workshop but I won't be purchasing this as well because of expense.
Gerry.
5th Jun 2021, 11:05 AM #19Most Valued Member
- Jul 2016
- 35
- 1,522
Thanks for the review I've been looking at these!
5th Jun 2021, 01:17 PM #20Diamond Member
- N.W.Tasmania
- 1,407
Disposable face masks - yes metal work related
By bollie7 in forum METALWORK GENERALReplies: 15Last Post: 21st Nov 2020, 10:40 PM -
N95 masks and metal grinding
By cheffernan in forum SAFETY FORUMReplies: 4Last Post: 9th Jun 2016, 03:01 AM -
auto-darkening masks from ebay/Bunnings
By jabell in forum WELDINGReplies: 54Last Post: 7th Aug 2014, 07:17 PM -
Dust and VFD's
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 22nd Apr 2014, 02:48 PM -
Welding masks - your preferences and opinions
By LordBug in forum WELDINGReplies: 23Last Post: 3rd Sep 2011, 02:36 PM
