Results 61 to 75 of 96
Thread: Importing a lathe to Aus
22nd Jan 2021, 09:26 PM #61Senior Member
- Near Rockhampton
- 270
4th Jun 2021, 01:15 AM #62Senior Member
- Jun 2020
- Freo
- 68
- 142
My end of march estimate ended up to be today. Just a couple of months late
It is one serious heavy lump of iron, took quite an effort just to get it in the garage, 1.6T. Moving it to the shed will be a major task.
I thought it was 10hp but it is actually 7.5 with a 10hp VFD, just a bubba
I think it will take a day or two just to clean off all the cosmolene.
4th Jun 2021, 06:17 PM #63Most Valued Member
- 70
- 1,513
I like it.
Nev.
4th Jun 2021, 07:58 PM #64Senior Member
- Jun 2020
- Freo
- 68
- 142
So do I
It has a couple of things that surprised me a little.
The compound slide has backlash compensation which i have never seen before.
The CSS, constant surface speed, has a worm gear to interface to the potentiometer that adjusts the speed as the cross slide moves inward.
The brake resistor is huge. Much bigger than i expected, 450mm long 50mm diam.
4th Jun 2021, 11:57 PM #65Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
5th Jun 2021, 11:57 AM #66Senior Member
- Jun 2020
- Freo
- 68
- 142
5th Jun 2021, 03:29 PM #67Senior Member
- Jun 2020
- Freo
- 68
- 142
Decided to hook it up to power to test it and do the run in, 90 mins , before pulling it to bits for the move to the shed.
I just used a normal 10 amp lead in a normal 10A socket. It works ok, probably fine if i keep it under 2.5HP load.
Run in is 10 mins at each of 9 speeds. Here at 268RPM.
5th Jun 2021, 05:33 PM #68Senior Member
- Jun 2020
- Freo
- 68
- 142
Reasonably quiet in top gear, the lower 2 gears are a bit louder
Virtually no vibration at any speed
Huge improvement over my old machine
18th Jun 2021, 06:56 PM #69Senior Member
- Jun 2020
- Freo
- 68
- 142
The new toy has been stripped ready for the move through the small door but getting 2 mates together on the same day is proving difficult, wives being the problem . Another week most likely, big job so needs a weekend. Why can't everybody be retired like me .
19th Jun 2021, 02:07 AM #70
Just for giggles, that 1.6 tonnes is sitting on a foot at either end of the bed, implying a bearing pressure of something like 1000 kgs (maybe 1100) at the motor end of the bed.
Is your shed's floor up to supporting the concentrated weight of your lathe? Will you need to reinforce the shed's floor with steel plates?
Also, I hope you have the rollers you will need to move the beast.regards from Canmore
ian
19th Jun 2021, 02:10 AM #71
19th Jun 2021, 12:29 PM #72Senior Member
- Jun 2020
- Freo
- 68
- 142
19th Jun 2021, 12:34 PM #73Senior Member
- Jun 2020
- Freo
- 68
- 142
Ian
I was originally going to import a Cyclematic machine, copy of a Hardinge with electronic gearbox. They are a bit small so in the end i capitulated and bought the 16" machine from a local supplier. If i had a bigger shed i would probably have bought both but i don't so had to pick the one that had the best coverage. I used a Hardinge many years ago and they are so nice to use for small stuff.
Mike
19th Jun 2021, 03:36 PM #74
Mike
Just remember that a broken tile or four may not provide the vibration free support that your new lathe requires.
It might be better to actually remove the tiles under the lathe's feet.
What I'm most concerned (?) about is that the floor's surface might not have the concrete density and strength that an industrial grade concrete floor should have. You may find that over time you need to periodically shim the lathe's feet to return the lathe to true level.
ianregards from Canmore
ian
19th Jun 2021, 04:06 PM #75Senior Member
- Jun 2020
- Freo
- 68
- 142
The mounting pads are only 75mm diam so i highly doubt those tiles will survive. I will put it down and am expecting the tile to break immediately. I just hope the general area tiles will survive as the tile floor is nice to keep clean. I have a set of 20 ton skates that have 7 or 8 100mm wide rollers in contact with the floor at any one time so hoping that is enough.
Importing used toolroom lathes?
By DoctorWu in forum METALWORK GENERALReplies: 43Last Post: 13th May 2011, 11:03 AM -
Granite references: importing or not
By Bryan in forum METALWORK GENERALReplies: 39Last Post: 7th May 2011, 09:57 PM -
More about importing from China
By neksmerj in forum METALWORK GENERALReplies: 16Last Post: 3rd Nov 2010, 08:59 AM -
Importing U.S. Mig?
By martrix in forum WELDINGReplies: 30Last Post: 23rd Feb 2009, 11:09 PM
