Results 1 to 14 of 14
1st Jan 2021, 08:13 PM #1Most Valued Member
- Charlestown NSW
- 1,673
Steel Grade - any ideas what I have?
Gday All.
I'm continuing cleaning and sorting my shed out and I have a lump of round bar (that used to be bright).
Its a bar end and the end is painted white ( I know that doesn't mean much)
On the end it has "38.10 B/S" Which I thought might have been a grade at first. Until I measured it at 38.10mm So now I think this means the dia and Bright Shaft (or steel)
Anyway, it also has some writing on the side in the good old yellow paint pen. I can't make out the first bit but there is a string of numbers which I reckon is 61660.
Ive just spent an hour on the net using a variety of search engines and I can't find anything that relates this number to a grade of steel.
Its not really that important to me but I'm curious what it is. For all I know that number might be totally unrelated to the grade.
So does anyone who knows more about steel than I have any ideas suggestions? I've had this bit for at least 20 years so it might also be an old number that is no longer used.
Thanks in advance.
Peter
1st Jan 2021, 09:02 PM #2Most Valued Member
Hi Peter, Found a Product Colour Code Chart from Atlas steel and it looks like it could be 8620H a case hardening steel.
The number you quoted, could be anything from an Invoice number to a stock or job number.
Have attached a link to the page for you and others.
http://www.atlassteels.com.au/docume...v_Dec_2003.pdf
Hopefully it will help, IF I'm reading it right
1st Jan 2021, 10:18 PM #3Most Valued Member
- Charlestown NSW
- 1,673
Thanks Kryn.
Might be. I cant even remember where or when I got this.
peter
2nd Jan 2021, 12:38 AM #4Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
If you really want to know what it is I can Xray a slice when I get back to work
2nd Jan 2021, 12:59 AM #5Golden Member
- Dec 2007
- 574
I found that once you start delving into steel colour codes you find that steel supplier/maker colour codes do not always agree, so now I slice off a thin section 2-3mm thick heat to cherry red and quench, if a files slides over the top then I figure it is some sort of flame hardening tool steel silver steel/drill rod/4140 etc and mark it accordingly for future. The Xray thing sounds nice though - is there a hobby version available ?
2nd Jan 2021, 02:03 AM #6Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
2nd Jan 2021, 03:17 AM #7Senior Member
- Perth, Western Australia
- 67
- 362
I have found this very useful when trying to figure out what grade a piece of steel is.
Tony
2nd Jan 2021, 08:41 AM #8Most Valued Member
- Charlestown NSW
- 1,673
2nd Jan 2021, 08:55 AM #9Most Valued Member
- Charlestown NSW
- 1,673
There's a full metallurgy lab at work but they haven't had enough people wanting to do the course so they haven't offered it for several years. Now the only teacher they had qualified to teach it has retired.
They are still doing NDT but even that has dwindling numbers.
About 20 years ago I was in a different position to what I am doing now and part of my job was machining tensile samples and impact (Sharpie) samples. I'd be presented with two bits of 20 - 25 mm plate that had been welded together so the size was about 300mm square.
I'd then have to slice it up using 8"X 1/8" slitting saw on a big old Metal Export mill into Sharpie samples. Several each from the weld root, the middle and top of the weld. Once cut they had to be surface ground and then notched. Had to be very careful not to loose the orientation.
One of the those jobs that I can remember clearly and have no desire to ever do again. lol
peter
2nd Jan 2021, 09:25 AM #10Senior Member
- 67
- 362
Some forty + years ago part of my training was to take the same samples you would have made, stretch, bend and generally brake them to see how they stood up. Others had to be polished to a mirror finish, etched then thrown under a high powered microscope or an electron microscope and checked.
I didn`t mind braking bits but the endless polishing was a pain I have not missed since those days.
Tony
2nd Jan 2021, 03:25 PM #11Golden Member
- Cairns, Q
- 666
Worth trying a spark test? There is a set of good spark test photos here:
https://www.scrapmetaljunkie.com/241...sting-metals-2
Frank.
2nd Jan 2021, 04:19 PM #12Most Valued Member
- Charlestown NSW
- 1,673
2nd Jan 2021, 04:20 PM #13Most Valued Member
- Charlestown NSW
- 1,673
4th Jan 2021, 02:16 PM #14Most Valued Member
- Healesville
- 2,129
G/day Bollie, i think that famillyguys idea of seeing if it will harden is a good one.
I recently was given this length of silver steel to make some parts and the paint on the end looks like it may have been white once upon a time.
What grade steel for cross/ compound screw
By monchochos in forum THE HERCUS AREAReplies: 3Last Post: 10th Aug 2018, 08:04 AM -
Grade 8.8 M16 Studding - Machining
By electrosteam in forum METALWORK GENERALReplies: 13Last Post: 19th Feb 2014, 07:28 PM -
Axle steel - what grade?
By Gavin Newman in forum TRAILERS & OTHER FABRICATED STUFFReplies: 4Last Post: 14th Aug 2012, 03:45 AM -
stainless steel grade for hardening
By thorens in forum METALWORK GENERALReplies: 6Last Post: 6th Apr 2012, 11:23 AM -
machining 1045 grade steel
By welder in forum METALWORK GENERALReplies: 2Last Post: 13th Aug 2010, 07:16 PM
