Results 1 to 4 of 4
    Tennant Creek, Aust
    61
    601
    Default Lubricant for Vices
    What do you use for lubricant on a vice?
    After spending hours scraping off hardened dried grease, dirt and crud, I don’t want it to end up like this again.
    It swivel at the base and the jaws swivel in the body.
    Before photo.
    Jan 2004
    Mackay North Qld
    6,446
    Dry graphite is what some manufacturers recommend.
    If you have any, perhaps white lithium grease might do?
    I don't see it it around anymore ,maybe its all going into battery manufacture?
    Regular cleaning and re lubing seems a good idea.
    7,189
    I use moly wheel bearing grease - its supposed to be good for slow-motion high-pressure applications. My 1967 purchased join vice got lubed that way in the 1980s and is still good and smooth.
    I also use small amounts of it in Guy Lautard's home baked way oil recipe.
    7,189
    I have some white Li grease as a spray, bought a new can last year.
    The spray is semi penetrating - I use it for lubing WW machinery.
    I generally blow the dust off the thing I'm (re)greasing, spary it on and let it dry. It dries as a thin solid layer that does't seem to collect as much dust as regular grease. By solid I don't mean hard like regular grease.
    https://www.supercheapauto.com.au/p/...0g/135464.html
  1. TNC Jewelers Vices
    By bwal74 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 6th Oct 2018, 09:38 AM
  2. Need suggestions for lubricant
    By rob streeper in forum METALWORK GENERAL
    Last Post: 6th Sep 2016, 02:05 PM
  3. Vices Size?
    Last Post: 29th Jun 2015, 09:56 PM
  4. Anyone used this Product? Lubricant.
    By bwal74 in forum METALWORK GENERAL
    Last Post: 28th Dec 2013, 11:57 PM
  5. Machine vices
    Last Post: 16th Apr 2011, 12:05 AM
