Results 1 to 9 of 9
Thread: Scotch brite belts
14th Dec 2020, 04:12 AM #1China
- Dec 2005
- South Australia
- 1,658
Scotch brite belts
I ran a search on this as I thought there was thread but nothing came up, Just wondering if any one has successfully rejoined broken (at the join) butt jointed Scotch Brite linishing belts
I have had 2 let go in as many days not new but plenty of life left in them at $15 each it would be worth fixing them
14th Dec 2020, 06:09 AM #2
Hi China, Guys,
They are not going to be easy to join at all. Initially I would used a strip of gaffer tape on the back, now you need to find a solvent, a bit like PVC pipe cement. Fold it back and paint the edge with solvent and keep your fingers crossed.
They do dissolve in some solvents, though I must admit I don't know what. I can tell you that I've had some Scotch Brite material disintegrate when in contact with a degreaser spray.Best Regards:
14th Dec 2020, 08:12 AM #3
I bought some sanding belts that were old but the price was too good. I have had a few "let go" so I did a search and found some joining tape on Timbecon's site. Its a Fast Cap product. As yet I have not used it but I did use some of their other tape to give me a white edge on some particle board and it worked just fine. My thinking is that the Fast Cap brand has some good stuff
Just do it!
Kind regards Rod
14th Dec 2020, 08:56 AM #4Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Scotchbrite belts.
Hello China.
The belts are joined with mylar tape and polyestereurathane adhesive. The glue is mixed with red desmodera accelerator and then heated under a press. This join is subject to moisture in the air and after a year or two will fail. The backing, or scrim will make it hard to join. Fiberglass tape has the strength but to get it to adhere to the scrim?
regards
BC
14th Dec 2020, 12:19 PM #5China
- Dec 2005
- South Australia
- 1,658
Thanks for the replies, sounds like it will be a hit and miss operation, may not not be worth the trouble.
15th Dec 2020, 11:39 AM #6Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
Tape it up on the back with a fibre reinforced tape and squirt a bit of cyanacrolate into the ends. If it doesn’t work you haven’t really lost anything other than a few drops of super glue and a bit of tape.
15th Dec 2020, 11:17 PM #7
I've had the same issue several times. It seems related to time, not use....
I have considered several time to tape the back and then sew the ends together with some thick cotton or this steel braid or cable....
I hqv3n't done it yet, but any thoughts?Cheers, Joe
16th Dec 2020, 01:03 AM #8China
- Dec 2005
- South Australia
- 1,658
Sewing now that is a thought, I have some heavy duty thread might give it a go and see what transpires. The 45k would sew that like butter
16th Dec 2020, 09:36 AM #9Member: Blue and white apron brigade
If you are thinking of sewing, try dental floss.
I made this strop belt about 13 years ago - don't use it much but its still together after all that time.
All the sewn edges are cut on a slope so thet don't catch anywhere provided the best rotates in teh same direction.
2 x 48” sanding belts
By jack620 in forum METALWORK GENERALReplies: 6Last Post: 17th Sep 2020, 08:42 PM -
Segmented belts
By DSEL74 in forum METALWORK GENERALReplies: 10Last Post: 15th Nov 2018, 03:06 PM -
Fatter Scotch-Brite wheels
By BobL in forum METALWORK GENERALReplies: 17Last Post: 3rd Nov 2018, 09:51 PM -
Linked V belts
By Swarfmaker1 in forum THE HERCUS AREAReplies: 11Last Post: 22nd Jan 2016, 06:59 PM -
Cogged belts - again
By eskimo in forum METALWORK GENERALReplies: 3Last Post: 27th Aug 2014, 11:09 AM
