Results 1 to 10 of 10
Thread: A wotcha call it is being sought
11th Dec 2020, 04:21 PM #1
Gentlemen,
I know it has a bloody name but I cannot for the life of me ,think of it, at this moment.
I would describe it as a hollow flexible, adjustable spiral wound, metal cable employed in supporting a microphone or desk lamp light bulb.
Yes I googled for it and found every thing else but There will a key word but I have not stumbled on it yet.
I require it to support a LED adjacent to my MultiTool linisher, mounted with the platen vertically at the moment.
You cant free hand grind too well and not do without the concentrated light when grinding up close and personal. The same arm/tube,I want to push aside when getting hot and heavy with other work.
In the past I have purchased a lamp from Big W solely to obtain the flexible coil arm but the length needed for this project exceeds the length available with the woolies lamp. If you can put a name to it that will be wonderful.
Your assistance is appreciated.
11th Dec 2020, 04:40 PM #2
11th Dec 2020, 04:41 PM #3Half baked bush welder
- Aug 2010
- Soldiers Point, NSW
- 60
- 10
11th Dec 2020, 05:30 PM #4Golden Member
- Aug 2015
- Melbourne, Australia
- 843
11th Dec 2020, 05:37 PM #5Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
I have one of those goosenecks with a light on it sitting around collecting dust if you want it Grahame. Was mounted on my mill by the previous owner, I took it off before it fell off into a cutter.
11th Dec 2020, 05:47 PM #6Intermediate Member
- Feb 2009
- Tasmania
- 43
Here's one that might substitute okay:
https://www.ebay.com.au/itm/110V-220...Cclp%3A2334524
11th Dec 2020, 07:02 PM #7
Gentlemen,
Thank you all.
There are some possibilities for me to chase up then.
Racingtadpole. Yes please!
I would love to have the light and gooseneck.
I''ll leave it to you when it suits best timewise . No hurry if it suits you as the xmas madness is about to start .
Im sure you got lots of Xmassy things to do and time will be in short supply.
I'll send you are PM.
Ta muchly
13th Dec 2020, 11:22 AM #8
Hows flexi shaft sound Grahame.?
Make the search Flexible ShaftLast edited by wheelinround; 13th Dec 2020 at 11:25 AM. Reason: Add
14th Dec 2020, 10:38 PM #9Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,183
If you can't wait for mail order delivery, there is probably a Jaycar up there somewhere?
AM4127-450mm-flexible-gooseneckImageMain-515.jpg https://www.jaycar.com.au/450mm-flex...eneck/p/AM4127
15th Dec 2020, 06:56 AM #10
Hi Gents,
I had originally tried various googled combinations of flexible shaft, spiral wound cable and spiral metal wound shaft.
The Jaycar item came up the very first time I Googled in "gooseneck. It was that key word.
After a phone call to the local Jaycar it transpired that they did not have one in stock. God knows how long an order might take,but given the current supply situation who knows?
The plan for the moment is to wait until xmas is done and dusted and allow the mail /delivery system to return back to its normal speed.
PS XJ90X the mag base one looks interesting.
Thank you All
Had a close call this week!
By Grahame Collins in forum GENERAL DISCUSSION / OFF TOPICReplies: 11Last Post: 25th Mar 2019, 02:49 PM -
What do you call it ?
By Grahame Collins in forum METALWORK GENERALReplies: 8Last Post: 22nd May 2015, 08:58 AM -
What do you call what you do in the shed?
By Michael G in forum METALWORK GENERALReplies: 31Last Post: 3rd May 2013, 01:57 PM -
You call that welding
By Tonto in forum METALWORK GENERALReplies: 49Last Post: 25th May 2012, 08:05 PM -
Now that's what I call metalwork!
By neksmerj in forum METALWORK GENERALReplies: 0Last Post: 13th Jan 2008, 05:30 PM
