Results 1 to 8 of 8
23rd Nov 2020, 09:43 PM #1Gear expert in training
- 34
- 1,080
Some of you make chips bigger than these gears...
Had to set up a hobbing job today for some tiny brass helical gears; 2 mm bore, 5.1mm OD, 3.5mm wide including shoulders, 15 teeth.
No fancy CNC, just a Swiss mechanical computer
Back end gear train; spindle speed on the right, indexing on the left
Front end gear train: basic feed on the right, differential feed for helicals on the left
5° 51'...or as close as I can figure it without a vernier scale. A few minutes either way on something like this isn't going to make much difference
It's a tight fit in there with the deburring tool
1 down, 2999 to go
And with some swarf from the lathe across the walkway for scale
23rd Nov 2020, 10:07 PM #2China
- Dec 2005
- South Australia
- 1,658
You working for a watchmaker now!
23rd Nov 2020, 10:14 PM #3Gear expert in training
- 34
- 1,080
Not quite, but we are instrument makers so I suppose watches could fall under that
That's not even as small as we can go, I have a gear that we used to make for the old mechanical power meters; 2.4mm OD, 0.8mm bore, 10 teeth.
23rd Nov 2020, 11:26 PM #4
Hi Elan, Guys,
Just don't drop it on the floor you will never see it again !Best Regards:
23rd Nov 2020, 11:34 PM #5China
- Dec 2005
- South Australia
- 1,658
Interesting when you see the tiny machines watchmakers use it is testament to the accuracy of those big machines and I the guess the bloke setting it up has a bit of input also.
24th Nov 2020, 09:36 AM #6Pink 10EE owner
- 6,218
24th Nov 2020, 11:05 AM #7
Hi Elan, nice work.
Seeing it certainly brings back memories of my dad.
On jobs like these, the first step is to fix the bottom of an apron to the base of the machine and the the loop around your neck.
My late father,a watchmaker had such a set up on his work bench.
If you don't have such insurance ,the miniscule part is almost guaranteed to leave your fingers and jump to where it can't be found.
The smaller the part is, the greater the chance of it taking an unplanned trip to the floor. Don't ask me how I know.
24th Nov 2020, 05:45 PM #8Gear expert in training
- 34
- 1,080
Mikron (the manufacturer of most of our small hobbing machines) was actually started by a watchmaker specifically for the watch industry. It's quite amazing that, once warmed up, these machines will stay within 5-10 microns all day, even 50+ years after being built, and all without a single computer chip. We even have a couple of electro-hydraulic hobbers from them that are able to run totally automatically, including load/unload, with nothing but micro-switches and solenoids. Well, they would if we had all the parts...
Bigger -better
By morrisman in forum METALWORK GENERALReplies: 1Last Post: 18th Nov 2014, 10:58 PM -
Two thou bigger at one end !
By BaronJ in forum METALWORK GENERALReplies: 38Last Post: 15th Feb 2014, 09:44 AM -
Mills and chips
By Michael G in forum METALWORK GENERALReplies: 4Last Post: 28th Jan 2012, 09:37 PM -
Cheap As Chips Welding Gloves
By matthew_g in forum WELDINGReplies: 12Last Post: 9th Sep 2010, 11:49 PM -
Red hot chips off lathe
By Tiger in forum METALWORK GENERALReplies: 9Last Post: 18th May 2010, 10:49 PM
