Results 16 to 17 of 17
20th Nov 2020, 06:58 AM #16Senior Member
- Feb 2012
- Tamworth, NSW
- 205
Thanks, and yes I tossed up which way to go. I don’t have a fly cutter yet and the fact that I want to turn a register for a small 3 jaw chuck onto the rectangular piece drove me to the lathe. My mill has a rotary table so all could have been done on it but I guess I though lathe may have been better.
I am calling it a mill but really it is a jig borer (BCA Mark 3). So really it is a very nice mini-mill if you like.
The plate is going to be a backplate for small 3 jaw chuck that will mount on the rotary table to hold round stock vertically for milling. I will use the mill to drill the centre hole and the hole circle for the chuck. I guess if I bore the centre hole (mill has a 1/2 inch hole in rotary table so I want to have a quick register using a pin through the backplate), drill the mounting holes, I may as well mill the register using the mill and know everything is concentric.
at the moment the backplate has been faced in lathe (average but passable finish) so now starts the tricky bit of getting register etc sorted.
20th Nov 2020, 08:32 PM #17
Hi Danger Mouse,
Fly cutters are not difficult to make. Mine took about an hour on the lathe and drill press. I think the hardest part was tapping the M6 thread in the right place.
Pictures of mine and the drawing for it. That disc is a 20 mm thick off cut from a stainless steel bar out of the scrap bin. I just cleaned it up and drilled it on the lathe. The shaft is a hot press fit, it isn't going to slip.
HTH.Best Regards:
Bending rectangular tubing
By rbtp in forum METALWORK GENERALReplies: 14Last Post: 30th Mar 2020, 12:51 PM -
Centering Hex stock in a 4 jaw?
By topari in forum METALWORK GENERALReplies: 3Last Post: 27th Jul 2018, 06:55 PM -
Centering stock in 3 jaw chuck
By oohsam in forum METALWORK GENERALReplies: 26Last Post: 16th Jun 2014, 11:17 AM -
How to cut a rectangular hole in a gutter
By ratchet in forum METALWORK GENERALReplies: 12Last Post: 6th Sep 2011, 08:20 PM -
Centering square stock in a 4 jaw chuck
By Dingo Dog in forum METALWORK GENERALReplies: 2Last Post: 11th Apr 2008, 09:13 AM
