Results 1 to 7 of 7
17th Nov 2020, 01:45 PM #1New Member
- Nov 2020
- Wynyard Tasmania
- 79
- 2
Where to obtain metal shafting and tubing in Australia
Hi Everyone,
I'm a woodworker who is about to build my first wooden clock, with the assistance of a CNC router. Among the materials I'm trying to source is reasonably accurately ground metal tubing (preferably brass - 1/4" or 6mm to start with, but other diameters further down the line) plus brass tubing to fit snugly over and provide bearings.
Can anyone suggest an Australian supplier? I've searched online but in vain and don't want to order from the USA if I can avoid it.
Any advice would be gratefully received.
Out of my depth (where metal is concerned)
Thanks and best regards,
Mervyn Mitchell
Wynyard, Tasmania
17th Nov 2020, 01:51 PM #2
Wall thickness and length/s required ?
There seems to be any amount on Australian Ebay.
Do not know about ground brass tubing, though.
Not so sure about using tube as bearings .My father was a watchmaker and by extension fixed all manner of clocks. He made bearings on a watch makers lathe or purchased the bearings - bushings really.
Welcome to the MetalWork forums.
17th Nov 2020, 01:55 PM #3Intermediate Member
- Oct 2012
- Wallerawang NSW
- 28
Look up E and J Winter model engineering supplies in Bathurst NSW - they have everything you want.
https://ejwinter.com.au/
17th Nov 2020, 03:28 PM #4China
- Dec 2005
- South Australia
- 1,657
My mate in Alice Springs makes wooden clocks, you won't find precision ground brass any where, you will need to machine your own from solid stock or find some one with a metal lathe that can do it for you
17th Nov 2020, 03:36 PM #5Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 455
Welcome to the forum Mervyn.
Ross
17th Nov 2020, 05:42 PM #6Gear expert in training
- 34
- 1,079
If you want off-the-shelf ground material that's relatively precise, silver steel (AKA drill rod) is probably your best bet (it doesn't actually have any silver in it, it's just called that because of how it looks); it's a form of tool steel which is easy to machine but is still fairly wear resistant in its unhardened state.
The sizes you'd need should have a tolerance around +0 / -0.015mm, so definitely not bearing level precision, but it's probably as good as you'll get without machining the material yourself.
18th Nov 2020, 04:49 PM #7New Member
- Nov 2020
- Wynyard Tasmania
- 79
- 2
Brass materials for wooden clocks
Thanks everyone for your fast and informative replies, which have enabled me to find an Australian supplier of brass rods. The bushings remain more elusive but a friend has told me he can machine them easily from thicker rods, so I'm now in business. I've just had an email from a well-known American clock maker who tells me that precision fitted bushings on precisely machined shafts tend to jam when the wooden frame of the clock undergoes inevitable sag - they mustn't fit too tightly, so it appears I was in danger pf over engineering the shafts and bearings anyway.
Thanks again folk!
Mervyn
A possible low cost alternative for hard to obtain sheetmetal rivets
By Grahame Collins in forum TIPS, TRICKS & HOW TO'SReplies: 5Last Post: 20th Oct 2020, 09:34 PM -
Looking for metal foils in Australia.
By tea lady in forum METALWORK GENERALReplies: 7Last Post: 3rd Sep 2012, 03:12 PM -
Metal Tubing
By garfield in forum METALWORK GENERALReplies: 4Last Post: 9th Dec 2007, 06:15 AM -
Copper tubing
By Priemsy in forum METALWORK GENERALReplies: 4Last Post: 3rd Aug 2007, 01:27 PM -
Bending S.S.Tubing
By ptrott in forum METALWORK GENERALReplies: 16Last Post: 9th Dec 2005, 09:07 PM
