Results 16 to 30 of 110
Thread: Delicate engineering problem
12th Nov 2020, 08:50 PM #16Most Valued Member
- Healesville
- 2,129
12th Nov 2020, 09:24 PM #17Gear expert in training
- 34
- 1,080
Would a simple Easy-Out and/or left hand drill work?
12th Nov 2020, 09:46 PM #18Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
12th Nov 2020, 09:52 PM #19Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I mentioned drilling the head off the screw, but didn't that didn't get a response from the guys trying to get it off.
They didn't have any LH ezy outs or LH drills but I thought a standard drill may work,as long as it didn't grab and I could stand the procedure.
Forgot to mention, the Perth Rep for the parts arranged for a Medical Engineering firm asssit with removing the screw, but it was not mentioned to them that they could hold the fitting in a vice and whack it with a hammer.....
( God knows why....... its fairly important information.)
12th Nov 2020, 10:07 PM #20Gear expert in training
- 34
- 1,080
13th Nov 2020, 02:39 AM #21
I get your frustration with the medicos.
Can you get onto the people in the Medical Engineering firm who know what's what and tell them directly that they can "hold the fitting in a vice and wack it with a hammer" ?
This would appear, at least to me, to be your first choice of action. Before you start on hand held nut splitters, ground down allen keys, etc.
and while we are talking -- I'm currently in Alberta.
Locally, Covid cases are currently running at around 600 per day in a population of just over 4.4 Mil, and we're heading into prime flu season when the case numbers are expected to worsen.
I'd describe the recent Covid situation in Australia as a "moral panic".regards from Canmore
ian
13th Nov 2020, 11:09 AM #22
No help, but...
I'm afraid I don't have any answers for you mate, but just would like to express sympathy... doesn't seen right that you have to go through this,
hang in there.
13th Nov 2020, 01:55 PM #23Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
13th Nov 2020, 01:58 PM #24Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
13th Nov 2020, 02:01 PM #25Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
13th Nov 2020, 02:41 PM #26Most Valued Member
- Healesville
- 2,129
In the past to become a prosthetist you would need to be a fitter and turner cabinet maker or maybe a mechanic, you needed to have skills with your head and hands before you got to even train for the job.
These days the prosthetists do some uni, unfortunatly many of them dont have the skills to do the work.
I lost a leg 44 years ago so i have had a bit to do with them.
In the old days it would take about 6 to 8 weeks to get a new leg, i got a script for a new leg in 2016, sacked that mob as they were not up to the task and went somewhere else, much better but i had to build an alignment jig for
them to use to try and get a walkable leg. Covid came along so i have put off going back there as i have been doing my own repairs and adjustments, it would be frustrating for those that cant use a hammer or screwdriver themselves...
13th Nov 2020, 03:21 PM #27Gear expert in training
- 34
- 1,080
13th Nov 2020, 06:04 PM #28Most Valued Member
Are you able to access the head of the socket or is it in a counter bore??
If it's exposed what about using a stud removing tool, this will grip the outside of the Socket head,Stud Removing tool.jpg, and should require about as much force as it took to stuff the bolt up
HTH
13th Nov 2020, 08:48 PM #29Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
13th Nov 2020, 08:50 PM #30Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Engineering toolbox
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 25th Nov 2014, 09:57 PM -
Clever bit of engineering
By nearnexus in forum METALWORK GENERALReplies: 4Last Post: 23rd Mar 2013, 06:30 PM -
An engineering question?
By neksmerj in forum METALWORK GENERALReplies: 18Last Post: 2nd May 2011, 12:40 AM -
It's all about engineering
By neksmerj in forum METALWORK GENERALReplies: 22Last Post: 9th Nov 2010, 09:23 PM
