Results 1 to 15 of 35
12th Nov 2020, 08:44 AM #1Golden Member
- Aug 2015
- Melbourne, Australia
- 843
X auto feed for bridgeport - is (M&G) '135lbs' enough?
Hi All,
Looking at putting an x axis feed on the BP. It is for home workshop use. mag pro sells these: X Feed 135Lbs. Power Feed_Machine Tool Access._M&G Productions, which are rated at '135lbs'. Anybody have any experience with them on a BP? EDIT: mag pro web site shows one attached to a BP ...
Some posts on practical machinist say all good with 135 so my feeling is it'll be good enough for me. But I look at the H&F ones for same: https://www.machineryhouse.com.au/M227, and they say 650 for a turret mill. That's like 5 times the M&G one ... (and twice the cost). That's a pretty large difference in specs - unless, of course, they are not comparing apples with apples.
All comments welcome,
Greg.
12th Nov 2020, 09:09 AM #2Most Valued Member
- Healesville
- 2,129
Greg 135 ft pounds is quite a bit of torque, if you have a torque wrench set it to that and pull on it, that will give you an idea of the power the drive should have.
Is the M&G unit is 240 v ?
12th Nov 2020, 09:38 AM #3Golden Member
- Apr 2018
- Drouin Vic
- 634
The HF one is 650 inch pounds, about 50-odd foot pounds. The M&G one just says 135 pounds, which is a weight not a torque so not much help.
Just thinking about the force required to manually crank the X-feed on my U2 when milling, if it needed 135 (or even 50) ft-lbs I'd know I'd left the table lock on.
12th Nov 2020, 10:00 AM #4Golden Member
- Aug 2015
- 843
Shed/Pete, thanks. Yes 135 ft lbs on the torque wrench is a fair bit. Good point both. Thanks. Not apples and apples. But, looking about it seems the M&G one is 135 inch pounds (others that advertise as 135lbs indicate inch lbs), which puts it at about 20% torque of the H&F one - if I read that right.
Interesting there is such a vast diff, but some comments here seem to indicate that it'll be okay: https://www.practicalmachinist.com/v...ed-buy-116757/
12th Nov 2020, 10:18 AM #5Most Valued Member
- Healesville
- 2,129
12th Nov 2020, 10:40 AM #6Most Valued Member
I'd see if you can get a power rating from M&G
The H&F one appears to be rated at 90W. If my maths is correct, with no losses thats max of 12rpm at 650in lb. About 50in lb at 160rpm. It is built in Taiwan and includes the parts needed for fitting, while I'm guessing the M&G one also includes them, it doesn't show them.
12th Nov 2020, 11:05 AM #7
The H&F unit is the unit supplied as standard on the Taiwanese BM-30 mill which is a Bridgeport clone. I haven't had any issues with it so far, it drives the table irrespective of how deep a cut I take.
12th Nov 2020, 02:40 PM #8
Note though that the H&F unit requires 110V, in the BM-30 it's supplied from a tap off the main transformer. Can't tell from the advert for the other unit, which has no specifications listed, whether that is also 110V or is 240V - or something different altogether.
13th Nov 2020, 08:24 AM #9Most Valued Member
- Jul 2016
- 35
- 1,522
The standard transformer im a brindgeport has taps for both 110 and 240 so you should be okay either way.
13th Nov 2020, 11:41 AM #10Golden Member
- Aug 2015
- 843
fyi: I spoke to Felix at M&G. He says it is 240v. No wattage figure though - so I've pinged him pack.
13th Nov 2020, 02:42 PM #11Most Valued Member
My pacific mill (lagun) Bridgeport clone came with a servo brand power feed 90 series. I assume its 90 ft-lb torque.
It no longer works but surely a 135 ft-lb for home use should be sweet.
14th Nov 2020, 08:26 AM #12Golden Member
- Aug 2015
- 843
Thanks Simon - I think it is actually inch lbs, not ft/lbs. So, 11.25 ft/lbs doesn't seem like a lot ....
Mind, here is the 450 in/lb version with free shipping to Oz for only a few bucks more: https://www.aliexpress.com/item/3288...3be032bdPLNrKG. And the 550 version also: https://www.aliexpress.com/item/3255...3be032bdPLNrKG. A little more $ than M&G for a lot more torque, and a lot less $ than H&F for a little less torque.
So, I reckon ali express finally gets a purchase from me.
14th Nov 2020, 10:00 AM #13Most Valued Member
- 4,890
Just note the more torque the longer before the clutch slips if something goes wrong.
8th Dec 2020, 07:54 PM #14Golden Member
- Aug 2015
- 843
To round this out. I got the 450in/lb model from ali express. Link given above.
It arrived today and I've installed it. Machine is a bridgeport 2j.
I have to say, i am impressed. I was expecting something a lot cheesier and more plasticy feeling. It feels solid - cast metal of some sort. The switches feel very good. The finish is pretty good. They body might be powder coated. The stickers are not already peeling off. Bonus.
The machined parts are done well and fit beautifully on the bp leadscrew. All parts were in the box for installation.
It took a bit if fiddling with the supplied shims and adjusting backlash to get it to feel the bevel gears engaged okay in both travel directions, but, i got there. Installation was about an hour or so.
It did say it came with an Aussie plug, but actually it arrived with a travel adapter to make it suit Aussie plugs. No big deal.
The auto stop mechanism works okay, but does feel a little flimsy compared to the other stuff.
So, all in all, pretty chuffed so far. Also, it arrived in under three weeks. Landed price, $374.76. So, about $85 more than mag pro, but 3 times the torque. About $300 cheaper than H&F at 70% the torque. I went and looked at the H&F ones and had a play. Cant say they felt any better quality. Maybe metal gears inside vs plastic or something. Dunno.
Anyways. Happy so far.
Edit. Pic.
9th Dec 2020, 08:53 AM #15Most Valued Member
- 4,258
any reason you didnt get the 650?
https://www.aliexpress.com/item/32557168592.html?spm=a2g0o.detail.1000060.1.7ab87de4fC5yKG&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=393d0462-46c0-4df0-9799-4739698dd315&_t=gps-idcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:393d0462-46c0-4df0-9799-4739698dd315,tpp_buckets:668%230%23131923%2327_668%23808%234094%23252_668%23888%233325%2315_668%232846%238111%23424_668%232717%237565%23797_668%231000022185%231000066058%230_668%233468%2315618%23929
and why does the site go wild when I click on products?...even that link I posted is no longer in english.
Bridgeport Clone Fine Feed Handwheel
By simonl in forum METALWORK PROJECTSReplies: 3Last Post: 27th Nov 2019, 06:51 AM -
Auto Feed Tapping Stand
By metaler in forum METALWORK PROJECTSReplies: 2Last Post: 18th Oct 2016, 03:48 AM -
Dividing head connected to x-axis feed on Bridgeport
By WoodBee2 in forum METALWORK GENERALReplies: 16Last Post: 4th Jun 2015, 09:28 AM -
Bridgeport Series 1 Mechanical feed gearbox
By Garry Edwards in forum METALWORK GENERALReplies: 4Last Post: 11th Dec 2013, 06:54 AM -
Home Made Surface grinder Auto Feed
By steran50 in forum METALWORK GENERALReplies: 0Last Post: 17th Aug 2012, 08:04 PM
