Results 1 to 11 of 11
    Nov 2008
    Perth WA
    6,459
    Default A Hunt for a Handle
    A while ago, during a conversation with BobL, I mentioned that I sometimes had a yearning to return to my woodie days and how it would be nice to have a small combination machine to facilitate that return. Bob's reply was "well it just so happens....."
    A long story shortened, Bob had a Woodfast Universal Woodworker that he was prepared to move on. More here https://www.woodworkforums.com/f153/...68#post2198168
    At present I'm working on the mitre gauge and I am wondering if anyone might have an identical handle they might be prepared to part with for a reasonable sum. The handle featured in the photos below is from the Universal's woodturning lathe attachment's tailstock and its 5/16" BSW thread is too short to lend itself to becoming a donor. I could turn up a knurled handle or use an over the counter plastic handle but I do favour the original.
    An option I am considering should no one have a box of these or even one sitting gathering dust, is to attempt a copy using cold cast aluminium. Could be an interesting adventure should my handle hunt prove fruitless.
    IMG_20201009_130833999.jpg IMG_20201110_144116070.jpg IMG_20201110_144141999.jpg IMG_20201110_144203671.jpg IMG_20201110_144217269.jpg IMG_20201110_144255172.jpg
    Bob.
    May 2011
    Murray Bridge S Aust.
    5,959
    Hi Bob, what length is required as a minimum????
    I have a few that look similar, won't be able to get a proper look till the weekend.
    Regards,
    Nov 2008
    Perth WA
    6,459
    Regards,
    The length isn't really too much of an issue Kryn because the handle requires a spacer to raise it up enough to clear the bosses for the stop rod. The spacer could be a threaded extension to whatever the existing thread is. The important thing is that the handle is the same as the Woodfast's.
    Bob.
    Aug 2015
    Melbourne, Australia
    843
    Hi Bob, make a new one from resin? Always fancied giving it a go ...
    https://www.youtube.com/watch?v=aNBHtlhlHF4
    Nov 2008
    Perth WA
    6,459
    Quote Originally Posted by StrayAlien View Post
    Hello Greg,
    Wesley's video certainly makes it look easy.
    My superficial investigation into the process so far suggests that a means of degassing both the silicone and the resin is required either by a vacuum or a pressure vessel. The silicone Wesley uses is available here https://www.rowetrading.com.au/produ...ial-kit-900gm/ and doesn't require degassing but isn't real cheap either. I'm hoping I might find something less expensive given the need for a single handle.
    Bob.
    7,189
    Bob, I have a schmiko vacuum pump you can borrow if you need one.
    Sep 2004
    Dardanup W.A.
    72
    331
    "If" these were near enough aesthetically, a bit of M12 allthread turned down and threaded to 5/16 BSW would do the trick.
    https://www.ebay.com.au/itm/M8-M12-B...YAAOSwvudeDYXT
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    I think I have sussed out how to machine one from Al solid using some of the trick bits I have here (Volstro head et al...). Had a play on the CAD system at work and I think it should work.
    Can always try that option if you like Bob.
    Nov 2008
    Perth WA
    6,459
    Thanks Bob. One obstacle removed.
    Quote Originally Posted by ptrott View Post
    Thanks for the suggestion Phill. If I was happy with a plastic substitute I would use a handle I already have, a German Lanker. I bought a bunch of them in Lucerne some years back and have yet to use them.
    Tricky machining Michael. The perfect radius on the ends of the raised ribs would be a challenge. Casting seems any easy alternative.
    Oct 2011
    59
    6,561
    Well yes, tricky machining but is there any better kind?
    Not sure casting would be much better as you still have to make a pattern.
    Nov 2008
    Perth WA
    6,459
    Michael,
    I would use the existing die cast handle as the pattern, avoiding any machining trickery.
    Bob.
  1. Another Vice Handle.
    Last Post: 18th Sep 2018, 09:58 PM
  2. Bridgeport speed handle
    By caskwarrior in forum METALWORK PROJECTS
    Last Post: 12th Jul 2017, 10:41 PM
  3. Handle of the cva quill.
    Last Post: 22nd Mar 2017, 05:02 PM
  4. What's the name of the handle that holds a tap?
    Last Post: 27th Nov 2014, 01:42 PM
  5. For those in the hunt for a AD welding helmet
    By garfield in forum WELDING
    Last Post: 21st Jul 2010, 07:19 PM
