Results 1 to 15 of 27
Thread: Bowed flat bar straightening.
2nd Nov 2020, 12:10 PM #1Intermediate Member
- Jun 2020
- Brisbane
- 54
- 41
Hi, I am making a welding table with flat bar strips for the top, however I did not think that my flat bar would not be flat. I have cut the 130x6 bar into strips but each one has a slight bow how do I remove this before welding? I don't have any type of rolling machine and only have a blow torch for heating if that is what is required. Thanks in advance for any help.
Cheers, Stu.
2nd Nov 2020, 01:33 PM #2Most Valued Member
I assume its bowed across the thick section otherwise you could just jump on it....
You could weld a series of small beads along the convex side of the flat bar to induce an opposing stress. This may help straighten.
The amount of weld at each point and the spacing will need to be worked out by trial and error.
2nd Nov 2020, 03:19 PM #3Diamond Member
- Aug 2006
- 1,106
6mm will straighten up easily, just work out where the bow is with a straight edge, set it up on blocks and give it a few hits.
2nd Nov 2020, 03:39 PM #4Most Valued Member
- 2,671
Or put a decent center support bar in the table and sit the flats on top with the ends curved upwards. The ends will be easy to pull down and and clamp for welding.
The middle will be solidly supported without having to weld it (which would likely make the flat bow a bit anyway)
2nd Nov 2020, 08:40 PM #5
130x6mm is getting up there to bend in a vice etc, I'd take Steve's advise, or other saying use a sledge hammer between something decent.
I'd use my press, but doesn't it sound like you have one.
If you have some spare steel laying around it would be easy enough for this project to build a small one out of a 1-2 tonne bottle jack. Even a sissor jack would work.
This way you could play with it to get it as strait as you desire.Using Tapatalk
3rd Nov 2020, 07:12 AM #6Most Valued Member
- Healesville
- 2,129
Lay the steel on the concrete floor and panel beat along the inside edge of the curve, you dont have to belt the hell out of it just lots of firm taps around the inside radius of the bend hitting it flat with the face of the hammer so you dont dent it and check with a straight edge as you go.
3rd Nov 2020, 09:33 AM #7Most Valued Member
- Healesville
- 2,129
Here is a simply knocked up tool that can be used for straightening or bending flat, shs and round tube.
Just add blocks of wood where required.
3rd Nov 2020, 10:46 AM #8Member: Blue and white apron brigade
3rd Nov 2020, 10:55 AM #9Intermediate Member
- Jun 2020
- Brisbane
- 54
- 41
Thanks for the reply's, woodworking is normally my thing so I would have just run it through the thicknesser . From the image you can see what I was trying to achieve, standing on it was probably the answer just didn't think it would be that easy. I have since welded the bolts on one side (teaching myself to TIG weld) and I think the problem is slightly worse. I will weld the rest today and see where I am once it's bolted down. Thanks for the help.
3rd Nov 2020, 11:00 AM #10Intermediate Member
- Jun 2020
- Brisbane
- 54
- 41
Pic 2
Don't know how to rotate this image.
3rd Nov 2020, 12:13 PM #11Member: Blue and white apron brigade
You have to save the image without the image specific data/properties ie delete the EXIF data.
Normally done in an image processing app.
Anyway I did it for you this time.
3rd Nov 2020, 01:23 PM #12Intermediate Member
- Jun 2020
- Brisbane
- 54
- 41
3rd Nov 2020, 02:07 PM #13Member: Blue and white apron brigade
3rd Nov 2020, 05:24 PM #14Member
- Dec 2014
- melbourne
- 72
I'm older than most trees too but even so I found this fellows explanation of what you can do to manipulate metal informative.
https://www.youtube.com/watch?v=w1XPDzunbY0
Robert
3rd Nov 2020, 07:32 PM #15
Hi Stooby
The easy way to get rid of the EXIF data is to edit the picture !
Rotate it as required and then crop the edges off then save it.
The EXIF data contains the information about the camera orientation when the picture was taken, the forum interprets that data to put the picture the same way up as the camera was when the picture was taken. There is a host of other data recorded there as well.
For instance my dash cam records the GPS coordinates along with the video.Best Regards:
Bending Flat bar
By tophi in forum METALWORK GENERALReplies: 8Last Post: 2nd Jul 2018, 08:47 PM -
Straightening a Loader Bucket
By RustyArc in forum METALWORK GENERALReplies: 9Last Post: 3rd Mar 2018, 10:30 PM -
Straightening an aluminium plate
By Marc in forum METALWORK GENERALReplies: 7Last Post: 13th Jan 2015, 08:44 PM -
Straightening an Allen-Key
By Fret Less in forum METALWORK GENERALReplies: 12Last Post: 16th Mar 2013, 10:48 AM -
Straightening lead screw
By Fossil in forum METALWORK GENERALReplies: 17Last Post: 12th Jun 2008, 09:39 AM
