Results 1 to 15 of 15
31st Oct 2020, 08:56 AM #1New Member
- Oct 2020
- Manchester
- 4
Advice on Speeding up drilling holes in flat bar
Firstly please excuse my ignorance on this subject.
I have started making brackets out of 40x6 flat bar and I am looking at advice how to speed up the drilling process. I currently drill 4 x holes using a 5.5mm HSS countersink bit. It works fine but for the volume we need to do I need to try and speed the process up a lot if possible.
All suggestions greatly appreciated
31st Oct 2020, 09:15 AM #2Member: Blue and white apron brigade
Don't really understand your question.
"I currently drill 4 x holes using a 5.5mm HSS countersink bit." and then what ??
Do you break the bit, is it just going too slow . . . . . . .?????
Some questions for you.
What are you using to drill the holes and what RPM are you using?
31st Oct 2020, 09:20 AM #3New Member
- Oct 2020
- Manchester
- 4
31st Oct 2020, 09:31 AM #4Member: Blue and white apron brigade
31st Oct 2020, 09:36 AM #5
If each of the 4 holes are in the same location on the parts, have you considered some kind of jig to make alignment simple?
Depending on the part you may be able to do multiple drilling operations on a single jig, otherwise batch process each part for each drilling operation (hole). ie don't drill all 4 holes consecutively on the one piece, but drill 20 brackets worth of hole #1, then 20x hole #2 etc...
Could be as simple as a few bits of angle iron clamped to the drill table to align with a hole location. Could be a very wild contraption if this is a significant manufacturing job...
31st Oct 2020, 09:49 AM #6New Member
- Oct 2020
- Manchester
- 4
31st Oct 2020, 09:56 AM #7
31st Oct 2020, 11:42 AM #8Senior Member
- Jul 2008
- Sydney Australia
- 142
31st Oct 2020, 11:43 AM #9Golden Member
- Apr 2018
- Drouin Vic
- 634
To expand a little on others' suggestions; I find that the things that make a difference when doing repetitive multiples is to get the cutting tool (i.e. drill bit and countersink) sharp and at the recommended cutting speed, and to minimise tool changes. i.e. if you are spot drilling, pilot drilling, finish drilling and countersinking, do each of those things on all of your brackets before changing tools; that way you only have to change tools four times for the whole job rather than four times per bracket. Use a fence on your drill table rather than the vice, that way you can just slide the workpiece along for each hole and hold it down with your hand- the fence will prevent it spinning (assuming we're talking smallish holes- if you're drilling 2" holes in brackets for a railway bridge or something, probably best clamp them down).
Running a correctly sharpened tool at correct RPM pays off in several ways- it will cut faster, and hold an edge longer.
31st Oct 2020, 01:02 PM #10Diamond Member
- Aug 2006
- 1,106
Depends how many you need to do, there are options such as setting up a gang of drill spindles so you have 4 drill bits in at the one time.
You could also look into punching them out.
31st Oct 2020, 02:07 PM #11Member: Blue and white apron brigade
I often put small deburrers in a cordless drill.
31st Oct 2020, 02:33 PM #12Senior Member
- Oct 2010
- NSW
- 181
You need one of these
and three friends.
31st Oct 2020, 03:14 PM #13Diamond Member
- Aug 2006
- 1,106
31st Oct 2020, 04:10 PM #14
The folk who like to 'work the wood' have a drill bit that countersinks in a single operation. Not sure if there is a trade quality equivalent for steel.
And like others have said, a quality countersink / de-burr bit on a cordless would whip the reverse side of the hole into shape.
31st Oct 2020, 10:28 PM #15Most Valued Member
Firstly, WELCOME to a TOP FORUM. As you haven't mentioned numbers that you're making, I presume that it's a job at home??? If it's a work related jobbing project, I'd suggest a punching machine, I used to make a product that required a lot of holes to be done.
I had a punch and shear machine set up with 5mm punch, this was punched into 3 mm thick angle iron, a small square plate was then welded over the punched hole then drilled and tapped. To speed things up I invested in several Drill Presses (Pillar Drills) One had the jig for positioning for, the correct sized drill bit, the next one had a countersink bit and the fourth one a tapping head fitted for a 6mm tap. I has 6 in total for other jobs as well.
The DP's were running constantly, you just moved the pieces along, there were something like 500 holes to be drilled and tapped per batch every other month.
HTH
Drilling square holes
By Groggy in forum METALWORK GENERALReplies: 11Last Post: 22nd May 2012, 01:12 AM -
Drilling holes
By brinesharks in forum METALWORK GENERALReplies: 9Last Post: 29th Nov 2009, 03:33 PM -
Drilling Holes with Rag
By Kody in forum METALWORK GENERALReplies: 1Last Post: 8th Jul 2009, 11:25 PM -
Drilling holes in steel
By henlan77 in forum METALWORK GENERALReplies: 17Last Post: 22nd Apr 2009, 10:24 PM -
Drilling big holes
By Vernonv in forum METALWORK GENERALReplies: 34Last Post: 28th Aug 2007, 10:07 PM
