Results 1 to 7 of 7
Thread: Bead Roller
30th Oct 2020, 06:30 PM #1Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
Bead Roller
I am considering purchasing a bead roller, but I don't know much about them.
Sheet metal projects that have a rolled wire edge caused me to consider purchasing a bead roller, and as Hare and Forbes have their cheapest roller (SJ-24D - Bead Roller) on special at the moment, and soon it is Christmas.......
Any advice would be welcome.
Thanks in advance,
Alan.
30th Oct 2020, 09:33 PM #2Novice
- Apr 2020
- Melb, Vic
- 12
I got a 24” bead roller earlier this year. Kang Industries’ Kaka roller was cheaper than H&F. Quality is good and used it to strengthen multiple flat panels.
I didn’t bother with a stand as it works great in a vice.
1st Nov 2020, 11:32 AM #3
November sale is on now @H&F why wait
If doing many a bead roll is the way to go doing by hand is long and time consuming.
1st Nov 2020, 05:44 PM #4Banned
- Aug 2015
- QLD
- 735
Yeah... get one of them yellow bead rollers from Hare and Forbes...
14th Nov 2020, 11:28 PM #5Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
I ended up purchasing a H&F SJ-24D - Bead Roller. Local pick-up for me - so no delivery costs.
Should create a worthwhile learning experience!
Thanks for the comments from Forum members. Most appreciated!
Regards,
Alan.
8th Jan 2021, 03:58 PM #6Golden Member
- Apr 2019
- 596
Hi Alan,
I just posted my own bead roller thread then saw this thread. Your machine states it will roll up to 1.2mm. Is there a physical limit at 1.2mm thickness or would a 1.3mm sheet of steel fit in it? I have some drawers to make but most of the cheaper bead rollers state a max of 1.2mm.
12th Jan 2021, 05:07 PM #7Novice
- Apr 2020
- Melb, Vic
- 12
I’ve seen the other thread is well going, so to help anyone who comes across this thread...
There isn’t anything physical about the bead roller that will stop material thicker than 1.2mm being inserted. The gap would actually allow close to 20mm thick material - but realistically the limitations are:
- Clamping pressure
- Bead die hardness
- Overall strength of the other components
As an example, even if rolling a bead in 1mm aluminium, you’d be struggling to reach the maximum die depth in a single pass. You have to slowly increase the bead size over multiple passes, with each pass roughly the same clamping pressure. This keeps everything within the limitations. But it also means with patience you can somewhat exceed the specifications.
Bead roller
By racingtadpole in forum WANTED TO BUYReplies: 8Last Post: 16th Dec 2019, 11:33 AM -
looking for a manunal swage and jenny, or a bead roller
By Opelblues2 in forum METALWORK GENERALReplies: 10Last Post: 13th Jan 2015, 10:13 PM -
Examining a fillet bead fracture
By Grahame Collins in forum WELDINGReplies: 17Last Post: 24th Aug 2014, 06:03 PM -
thin weld bead
By eskimo in forum WELDINGReplies: 19Last Post: 25th Nov 2012, 11:13 PM -
SOLD: New Bead Roller
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 15th Feb 2012, 04:50 PM
