Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Nov 2012
    Mid North Coast NSW
    423
    Default How to remove pulley
    What do ya reckon is the easiest way to remove this pulley. It seems a bit stuck, and I don't want to break the motor casing.
    2hp motor and the pulley is 4" long x 4" diameter and has 2 grub screws (removed already) and a keyway.
    6,473
    Hi Phaser,
    A pin down the bore and a plate under the back. A pair of "G" clamps and a Bar across the pin. Heat the alloy pulley if wont start to move.
    Once you’ve got it moving then don't stop if its hot, if it cools it could grab !
    Dec 2005
    South Australia
    1,657
    If you don't have one borrow or rent a puller
    Nov 2012
    Mid North Coast NSW
    423
    Unfortunately not so easy with this one.
    The hole in the pulley for the motor shaft does not go all the way through (it's a blind hole).
    Mar 2011
    Southern Flinders Ranges
    1,552
    Make a couple of U shaped wedges, put them between the motor and pulley (maybe put something in to protect the motor casting too) then squeeze them together with a clamp. Judicious use of heat if it doesn’t want to split under tension.
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by phaser View Post
    Given the outer pulley is buggered anyway, could you cut it off with a hacksaw? That might expose the hole in the pulley and allow the use of a puller. If it doesn't, you could drill the hole out and clean it up later on the lathe.
    7,188
    I agree with Jack, Pulleys are cheap and easily replaced or turned up.
    Jul 2006
    Athelstone, SA 5076
    4,258
    ditto .....if you cant get hold of a puller
    Nov 2012
    Mid North Coast NSW
    423
    I did wonder about doing it that way.
    also I don't really have a suitable puller. The ones I've got would prob break the pulley rim instead of move it, so I'd have to make up something to go behind it (was hoping to avoid that).
    Never know when someone has a simpler idea to yours.
    Sep 2008
    Riddells Creek, Vic.
    836
    If you are not interested in saving the pulley you could try supporting the motor on a block of hardwood directly under the green painted boss and giving it a few hits longitudinally around the boss with a large cold chisel to expand the bore slightly, if hit in the right place and hard enough it might even crack open along the keyway.
    Dec 2014
    melbourne
    72
    Drill the center and tap M8-M10 . put a screw in to push against the shaft. hopefully there will be enough thread length left.
    Robert
    7,188
    Quote Originally Posted by shedeng View Post
    Robert
    Worth a go, but it assumes the shaft is not snug or close to the bottom of the pulley hole. If it’s snug even a bottoming Tap won’t clear out enough thread to allow the bolt to pass through to press onto the top of the shaft. If there’s a drilled and tapped hole in the end of the shaft the tap could also damage that thread.
    Oct 2015
    melbourne
    473
    If you can't tap to the bottom, drop a ball bearing in before the pusher bolt.
    If there's not enough depth for a thread (need 3 or 4 threads I believe) you'll have a hole for a puller
    Nov 2012
    Mid North Coast NSW
    423
    Sorry, what i meant to say is simpler idea to mine (generalization).
    I do like the idea of drilling and tapping to see if a bolt will push it off, so that's what I'm doing now.
    If that doesn't work I can drill it out bigger to let my puller go through to the shaft.
    The thing is, I don't mind cutting off the broken small pulley end but I don't want to destroy it completely because if for some reason I can't complete a new pulley then I can put it back on and keep using what I've got.
  15. #15
    Nov 2012
    Mid North Coast NSW
    423
    So I cut off the damaged end of the pulley and tapped it M12, then used a long coach bolt (needing a long thread) and it came off easily.
    Trying to hold the pulley whilst tapping the thread was the hardest part.
    Oh and by the way ..... does anyone know the correct belt contact face angle for B section pulleys ?
  1. Ways to remove stubborn set screw in motor pulley?
    By Gunnaduit in forum METALWORK GENERAL
    Last Post: 27th Jul 2018, 05:50 PM
  2. How To Remove Old Silastic, Etc.
    Last Post: 30th Jan 2016, 08:33 PM
  3. How to remove rust protection
    By woodfast in forum METALWORK GENERAL
    Last Post: 21st Aug 2014, 11:30 PM
  4. How do I remove old grease
    By Bidgee in forum METALWORK GENERAL
    Last Post: 14th Apr 2010, 10:00 AM
