Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Newbie Asks!
    Oct 2005
    Balwyn North
    72
    28
    Default Newbie Asks!
    Hi, I am a skilled handyman & skilled woodworker, but I am new to lathe work. I intend to buy the H&F TU-200V lathe as I have limited space.
    If any members are interested in replying, I like to hear your Three Best Tips for a Newbie. Peter
    Sep 2009
    Sydney
    666
    1. Watch loads of YouTube videos (This Old Tony, Joe Pie, Blondiehacks)
    2. Start with HSS tooling
    3. Use your machine loads and experiment with speeds and feeds to get a feel for what works.
    May 2013
    Rockhampton, QLD
    68
    455
    Welcome to the forum Peter.
    Ross
    Oct 2005
    Balwyn North
    72
    28
    Default Hss
    Thanks Neevo, I'm a fan of Tony & Clickspring, just discovered Blondiehacks & will have a squiz at Joe. Why HHS over carbide? Peter
    Quote Originally Posted by neevo View Post
    Sep 2009
    Sydney
    666
    HSS is way more forgiving than carbide, so I found when I was learning it helped me get the feel without the risk of having to take big cuts that carbide needs. Let alone chipping insets all the time.
    Nov 2009
    australia
    57
    Just remember that it is a S-M-A-L-L lathe, suitable for model making.
    If that's what your after, then go for it, as it's from Scary Forbes and they have a good warranty system going.
    If you are after something that will do brake disks or drums for your car, then this is not the lathe you require.
    ------------------------- Description
    TU-2004V - Opti-Turn Bench Lathe
    Ø200 x 300mm Turning Capacity - Ø21mm Spindle Bore
    Electronic Variable Speeds 150 ~ 2500rpm
    Overview
    Ideal for the model maker machining miniature parts
    Small in size but packed full of features, this miniature lathe could provide the perfect introduction to those wanting to start metal turning for the first time.
    The machine is small enough to fit into the corner of the workshop and with a weight of 75kg the bed is constructed form cast iron for true rigidity. This model turning capacities is 200mm diameter and 300mm between centres and with a 21mm spindle bore its surprisingly large for a machine of this overall size.
    Features such as the electric variable speed control, manual or powered leadscrew feed, metric & imperial thread cutting and an extensive range of accessories. The lathe comes supplied with 100mm diameter three jaw self-centring chuck, tailstock centre and service tools.
    7,189
    See if you can find an experienced turner you can watch and then get him to watch you turn so he (or she) can tell you what you are doing wrong.
    One hour with a pro will save 20 hours of youtube watching time.
    You tube is more useful once you have a bit of experience.
    Avoid practicing only on any old junk steel, at some stage early on buy some free machining steel so you can get some experience turning nicer material.
    Oct 2005
    Balwyn North
    72
    28
    Default Lathe
    Thanks Bob, every time I have wanted to make something it has been a flange, special bolt, a spacer. I make a lot of woodworking jigs & a lathe will make a difference between bonza & half arsed.
    Quote Originally Posted by mardtrp View Post
    Overview
    Oct 2005
    Balwyn North
    72
    28
    Default Lathe
    Thanks Bob, There is a model railway nearby. When we are out of covid, I hope that my handyman, gardening skills will get me a gig on the tools!!!
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    760
    Think you will probably outgrow it pretty quick. Know you have limited space, but well worth trying to make the space work with something bigger.
    Yes HSS, espec for interrupted cuts. As already stated, carbide generally likes it better if you can take heavier cuts.
    Good luck with it.
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
    Oct 2005
    Balwyn North
    72
    28
    Default Mini Lathe
    Thanks for the replies! A couple of queries
    1- Where do I get HSS cutting sets to get me started?
    2- Has anyone dealt with Ausee, the Sieg supplier. They have not responded to my emails & seem to be out of most stock?
    Jan 2004
    Mackay North Qld
    6,446
    If Aussee is out of stock LPR toolmakers will likely have some HHS lathe bits as they have recently had new shipments of tools and other bits and pieces.
    Understand that that shipments of all manner goods has been slowed down for reasons relating to the bat stew virus.
    I have dealt with Aussee tools and found them to be quite satisfactory. I purchased a 3" bench block from them and was happy with all aspects of the transaction.
    A phone call is much quicker as some seem to delay their Email responses.
    Jan 2004
    Mackay North Qld
    6,446
    Quote Originally Posted by Repete View Post
    High speed steel even with the necessary tool holder is way cheaper than carbide and stands up well to intermittent cuts.
    Carbide has a tendency to chip at the point while doing intermittent cutting. Each carbide shape needs its own specific tool holder and the cost of multiple shaped units can mount up after a while.
    Also I understand that carbide needs more power to drive the turning and and lot of smaller bench lathes just do not have the required grunt.
    An advantage of HSS is that it can be shaped to the users needs. If no one has mentioned it thus far, a bench grinder with a pair of aluminium oxide wheels say 60 and 100 grit (the white ones) is a necessity for shaping the HSS blanks. one can also sharpen HSS drill bits on this grinder.
    It does not take long to pick up the skill and lots of information is readily available on the how tos on grinding HSS.
    I had a need to fit a circlip on a shaft and the HSS was ground to enable turning a tiny groove to accommodate the width of the circlip. In that respect HSS beat carbide hands down and the reverse end of the HSS tool was still available to use for another purpose.
    I Hope this helps You
    Oct 2005
    Balwyn North
    72
    28
    Default Hss
    Thanks Grahame, thanks for the tips. I have a good grinder sitting in a cupboard since I bought a Tormek for tool sharpening. I wish I had started this years ago!!
  15. #15
    Jul 2008
    near Warragul, Victoria
    3,726
    Default Hss
    Hi
    HSS does a great job, but be aware its not all the same. I have collected many used , old pieces of HSS . HSS Comes in many brands , just experiment and see how you go . I have some old vintage pieces marked STELLITE and other vintage brands. I find the edge lasts far longer when some type of machining fluid is used, anything is better than nothing . Good luck This a 4-5mm cut using a little 3/4 hp lathe , back gear engaged
  1. Another newbie!
    By CaptainCaveman in forum G'day mate - THE WELCOME WAGON -Introduce yourself
    Last Post: 4th Aug 2020, 10:25 PM
  2. Newbie
    By XR750 in forum G'day mate - THE WELCOME WAGON -Introduce yourself
    Last Post: 12th Oct 2019, 04:51 PM
  3. Newbie looking
    By cookie48 in forum METALWORK GENERAL
    Last Post: 17th Mar 2012, 10:16 AM
  4. Newbie says hi :)
    By tribal in forum WELDING
    Last Post: 8th Mar 2009, 03:45 PM
  5. Hughie asks:
    By RETIRED in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 5th Sep 2006, 11:07 PM
