Results 1 to 10 of 10
Thread: What is this?
21st Oct 2020, 09:39 AM #1Most Valued Member
What is this?
So I've had this (what seems to be) hydraulic ram for a couple years. Got it for $20 and figured if no good then maybe able to use the parts.
Anyway, got around to taking it apart and was surprised at what I found.
The actual piston is all steel and undersized.
To give you an idea, the bore is 60.00mm and the piston is 57.75mm approx.
No seals and seemingly nowhere to attach a seal.
This ram has a port in the base as per usual and had a hydraulic hose attached, I threw it out as it was damaged.
Cant work out what is does or what its used for.
Couple things;
Is it missing a piston seal. If so, how does it attach?
Is it some type of hydraulic damper? But it still would have a sloppy fit with metal on metal.
Any help much appreciated!
21st Oct 2020, 10:41 AM #2Senior Member
- Jan 2012
- 149
Its a displacement cylinder:
Delta Hydraulics - Australian Hydraulic Cylinder & Telescopic Hoist Manufacturers
21st Oct 2020, 11:08 AM #3Most Valued Member
Thanks for the link.. That makes a lot more sense now.
21st Oct 2020, 07:47 PM #4Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Fitted to a lot of old tractor front end loaders.
21st Oct 2020, 07:53 PM #5Most Valued Member
So, i assume with a small amount of handiwork i could convert to a standard single acting hydraulic ram?
21st Oct 2020, 09:37 PM #6Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
21st Oct 2020, 09:41 PM #7Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
21st Oct 2020, 10:12 PM #8Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
I know very little about hydraulic rams.
How is it that it can have no seal?
21st Oct 2020, 11:37 PM #9Most Valued Member
Read the link in post #2
22nd Oct 2020, 06:49 PM #10Intermediate Member
- Feb 2009
- Tasmania
- 43
That ram is very similar to the rams on my Horndraulic Loader that is fitted to my Nuffield tractor - single acting as someone else mentioned. I'm sure that it could be used for a multitude of projects, even a long range hydraulic press with suitable springs to retract the ram.
