Results 1 to 9 of 9
    6,475
    Thumbs up Scrapyard find !
    I've been having a root around some new stuff in the local scrapyard. I picked up a plastic carrier bag with about a dozen bearing races in it. Among them were these three Timken ones
    They are taper roller races. I haven't a clue what they are or what machine they would be for. There is a large warning on the back of the packet "Not to be removed until ready to install" which suggests that they could be expensive ones.
    Anyone have any ideas !
    Aug 2015
    QLD
    735
    If you haven’t already then do a google search of the part numbers..
    Apr 2013
    Toowoomba Qld
    401
    https://cad.timken.com/item/all-prod...-2/16150-16284
    https://www.bearingbasement.com/p/be...oller-bearing/
    Just looks like tapered roller bearings, imperial ones for general fab, nothing special or amazing. They all have the warning about not to remove until you are ready to install
    6,475
    Thanks Guys,
    I thought it odd that someone would throw out a carrier bag with about 15 various obviously new bearings in it. They were wet, but had been sitting in the rain for some time. A couple have some rusting on the edges but in general are all quite usable.
    The manufactures date on the boxes is 1995 so they are at least 15 years old. When I spotted them I thought that they might be lathe spindle bearings of some use to someone. They are also inch sizes not metric ones.
    Thanks for the links, when I tried Google came up with all sorts of rubbish !
    May 2011
    Murray Bridge S Aust.
    5,959
    Nice score. I think you'll find that they are a wheel bearing to fit a large vehicle, or bearings for your next project, machinery skates. That is when all the other projects are finished and nothing on the "Honey Do" lists
    Aug 2015
    QLD
    735
    Watch “Shurap” on YouTube and you will find a whole new use for them bearings..
    Damascus steel.
    6,475
    Quote Originally Posted by YBAF View Post
    Damascus steel.
    No ! I'm not into knife making
    Charlestown NSW
    65
    1,673
    There is a large warning on the back of the packet "Not to be removed until ready to install" !
    Baron. That warning is basically there to reduce the chance of dirt etc getting into the bearing before installation. It doesn't take much to ruin a bearing.
    Peter
    Jul 2008
    near Warragul, Victoria
    3,726
    Default more
    Rear Differential Bearing by Timken®. Get optimum vehicle performance with Timken bearings. Timken manufactures ball bearings, cylindrical roller bearings, and tapered roller bearings, and all feature premium design, enhanced surface finishes, and are manufactured using quality materials to ensure longer bearing life and excellent antifriction properties.
    Brand:Timken
    Part Number:16150
    UPC:053893190945
    Warranty
    Timken Alcor Aerospace Technologies, Inc. and Bearing Inspection, Inc., collectively known as Timken Aerospace Aftermarket Solutions (“TAS”), provide the following limited warranties to customers for manufactured parts and for engine, component, part overhaul. FAA-PMA replacement parts (“PMA Parts”) will be free from defects in materials and workmanship, as defined by TAS standards, and will conform to the descriptions provided in writing by TAS for a period of 12 months,1000 hours, or the cycle limit of the part as defined by the applicable engine operations and maintenance manual, whichever occurs first, from the date of installation (“warranty period”).
    Vehicle Fitment
    Daihatsu
    Rocky 1990-1992
    Ford
    Taunus 1956-1960
    Zephyr 1956-1961
    Zodiac 1956-1961
    Mercury
    Capri 1971-1974, 1976-1977
    Triumph
    Stag 1971-1973
    TR2 1954-1955
    TR250 1968
    TR3 1958-1961
    TR4 1963-1967
    TR6 1969-1976 more details on - https://www.carid.com/timken/front-d...mpn-16150.html
  1. Scrapyard Gold !
    By BaronJ in forum METALWORK GENERAL
    Last Post: 28th Oct 2018, 08:06 AM
  2. More Scrapyard Finds !
    Last Post: 6th Jan 2018, 04:48 PM
  3. Scrapyard goodie.
    Last Post: 8th Jul 2017, 07:56 AM
  4. Scrapyard goodie !
    Last Post: 4th Oct 2015, 09:45 PM
  5. Scrapyard find !
    Last Post: 24th Jul 2015, 03:43 AM
