Results 1 to 11 of 11
Thread: Ryco male air fitting dimension
16th Oct 2020, 02:24 PM #1Most Valued Member
Afternoon all
I'm working on a hose roller that uses a Nitto air fitting to lock the reel to the base.
By the look of it a Ryco fitting might be better(though I am likely over thinking things again)
If someone uses these and has one handy I'd like to know the outside and inside dia of the male fitting and how many ball bearings in the female?
https://www.bunnings.com.au/powerfit...tting_p6210506
TIA
16th Oct 2020, 03:21 PM #2Member
- Nov 2016
- Gulfview Heights, Adelaide
- 83
I use Ryco fittings.
There are 3 ball bearings in the female fitting.
The male fitting is 3/16" diameter internal.
The external diameter depends on where you are measuring. The diameter at the end is smaller than near
the base.
regards,
paul
16th Oct 2020, 03:29 PM #3Most Valued Member
Thank you
The larger of the two please.
16th Oct 2020, 03:38 PM #4Member
- Nov 2016
- 83
Ok, the external diameter does not appear to be a nice imperial fraction size, in metric it is 11.25mm
hope this helps.
16th Oct 2020, 03:43 PM #5Most Valued Member
It does indeed help.
Thank you
16th Oct 2020, 09:11 PM #6Most Valued Member
- 5,945
Just a quick note, that the Ryco fittings and the Ryco STYLE of fittings are NOT interchangeable. DAMHIKT
16th Oct 2020, 10:33 PM #7Most Valued Member
I am going to ask. Do you happen to recall why?
It's unlikely to be an issue as long as the 11.25mm dia is pretty close. I won't be using the seals. At this stage I wont be using the male fitting, the groove will be turned onto a shaft. I will only be using the ball bearing locking parts. The inside Dia will only matter if I end up using the male fitting and then it will just have a bolt through it to hold the fitting in place. The Ryco gets the nod because 3 big bearings with a big groove seems to be better than 6 small bearings.
16th Oct 2020, 11:04 PM #8Most Valued Member
- 5,945
I can't really place what it is that's different, but they won't seat properly. It's probably OK if you got both parts from the same supplier.
I've converted most of my gear to Nitto as they have a larger bore in the male parts, to allow more air flow.
17th Oct 2020, 06:47 PM #9Most Valued Member
One more thing I didn't think of, I assume these are easy enough to get apart to get the guts out?
17th Oct 2020, 09:08 PM #10Most Valued Member
- 5,945
Yes they screw apart, unfortunately sometimes at the worst possible moment
17th Oct 2020, 09:40 PM #11Pink 10EE owner
- 6,216
Kipp Handle Dimension
By Anorak Bob in forum THE HERCUS AREAReplies: 2Last Post: 16th Feb 2020, 04:42 PM -
Fitting Reg to bottle
By DSEL74 in forum WELDINGReplies: 5Last Post: 14th Mar 2016, 10:07 AM -
Fitting a DRO to my lathe
By tbonesmith in forum METALWORK GENERALReplies: 2Last Post: 26th Mar 2014, 12:15 PM -
measuring the male dovetail
By eskimo in forum METALWORK GENERALReplies: 10Last Post: 4th Mar 2014, 07:43 AM -
Fitting an ER 40 to an AL320G
By barkersegg in forum METALWORK GENERALReplies: 16Last Post: 11th Nov 2010, 08:21 AM
