Results 1 to 15 of 18
11th Oct 2020, 01:42 PM #1Most Valued Member
- 4,890
HM 52 or similar Face Mill Cast Iron
Just curious if any one has been using a 100 or125 face mill runnng SEKT inserts on their machine.
Holder is KM12 type
If so what results are you getting?
What depth of cut are you achieving?
Are you feeding above 100 mm/ min?
What RPM are you running ?
Are you using SEKT or SEHT inserts?
Thank you.
12th Oct 2020, 11:58 AM #2Most Valued Member
- 4,258
75 mill face with sekt on the BM30 and result was crap....have not tried it since....I put it down to faulty inserts from Banggood...
12th Oct 2020, 01:27 PM #3Most Valued Member
- 4,890
Thank you for the reply, I have 100 plus face width that I am currently machining with a 80mm face mill , depth of cut varies between .5 and 2.5,mm.
Have squared the head as best I can.
Really looking to see if any one has been able to achieve an exceptable finish with minimal step if any, between the two cuts, and also what type of tip life are you getting from the cutting tips.
Dont really want to buy a 100 mill cutter and arbor if good results can't be achieved.
I would class a .05mm or less step as good and .07mm step or less as okay.
12th Oct 2020, 04:56 PM #4Golden Member
- Oct 2001
- ACT
- 667
While I am not going to be mean much help here , your question reminds me of the time back in the ETSA apprentice training centre wher one of the instructors got tired of us taking smallish cuts with the big face mills.
So as a demo he set up on the big Mazak mill the biggest face mill he could find and set the machine for the fastest speed and fastest feed and let it rip. Well there were blue hot chips the size of your finger nail flying all over the place not to mention people dashin around trying to avoid getting hit by the them or stopping them going down the front of your shirt.
12th Oct 2020, 07:13 PM #5Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
A facemill that big is going to be a struggle in that size machine you will be a lot better off with a flycutter.
12th Oct 2020, 07:14 PM #6
Hi Pipeclay,
My go to tool for that sort of work is a fly cutter ! I'm sure you have seen pictures of the ones I make.
This one is a 20 mm thick 75 mm diameter disc on a 20 mm shaft.
Your mill is heavier than my little BF20 so a larger diameter would cut full width.
I do have a 60 mm insert face cutter but it is really too big for my mill and the finish is rubbish !Best Regards:
12th Oct 2020, 09:41 PM #7Golden Member
- Dec 2011
- 505
Interesting flycutter.
Apparently some euromills have as acccessories heavy discs to be attached to the spindle when facemills are in use That increases the inertia of the rotating mass to thereby smooth the cutting, reduce chatter and reduce vibration in the drivetrain.Last edited by WCD; 13th Oct 2020 at 04:42 PM. Reason: grammar!
13th Oct 2020, 12:26 AM #8
The rationale behind the design of my fly cutter was first, rigidity, 20 mm is the biggest diameter that I can hold in my tool collet on an MT3 arbour. Second was balance. A hole just big enough to hold a 6 mm square of HSS tool steel with a 2 BA grub screw. I've spun this at the maximum speed of my mill, 2200 rpm with no noticeable vibration at all. Third tool deflection, a 1 mm depth of cut is possible but my mill struggles with that. As far as bulk metal removal is concerned 0.5 mm or about 25 thou is comfortable, but a 2 thou finishing cut leaves a mirror like surface on most materials except plastics, where it looks like it needs a shave.
I've also made a couple of small ones, mainly for producing a flat bottomed hole and a dovetail or two.Best Regards:
13th Oct 2020, 12:47 AM #9Intermediate Member
- Jun 2020
- Bacchus Marsh, victoria
- 27
Hi Baron,
I loved this posting because of your references to 'mm' , 'thou', '2BA', .
Us colonials can be quite adept at manipulating units, but your reference to BA threads; well I have to ask.
Aussie manufacturing, up until about 1975, was pretty much BSW, BSF, and for small stuff, BA. I have a box full of 5BA screws and sets of BA taps. I even have the number drills for the tapping sizes.
The US car makers particularly, introduced Unified threads. My old Vauxhalls had UNC/UNF threads, so I guess Britain had a mix of BSW/BSF/UNC/UNF. I had a 1961 Humber which used BSW/BSF threads.
So is the BSW/BSF thread forms still widely available in the UK or has the UK gone Metric because of the EU/ECM. And, what is the status of BA threads?
I would be interested to hear your comments on this subject.
regards,
rumpfy
13th Oct 2020, 01:36 AM #10
Hi Runpfy,
I haven't been called a "Colonial" for a very long time .
Yes all the thread forms that you mention are still around ! My use of BA threads was simply because I have some quantity of them and at one time quite involved in electrical engineering.
I was in fact looking at a box of taps the other day sorting out the different threads. I keep picking up odd ones at various places that I visit now and again. Mainly because old or damaged taps and cutters are good tool steel that can be pressed into service for other purposes.
Engineering firms today don't even bother sharpening cutting tools anymore, they just throw them into the scrap metal bin. A scrap yard that I frequent has an 8 ton skip almost full to the brim with carbide inserts, cutters and the like.Best Regards:
13th Oct 2020, 01:38 AM #11Most Valued Member
- 4,890
Thank you for the replies.
The job could be performed with the use of a fly cutter, but the time it would take and the number of cuts required would not be realistic at present.
Currently around .125"/3mm of material needs to be removed from each face.( roughing )
The use of a fly cutter would probably be feasible for a finish cut.
The 80 mm cutter is performing well the only limitation on this machine is a reduction in feed is required above 2 mm depth of cut.
13th Oct 2020, 01:49 AM #12
Hi Pipeclay, Guys,
Yes I understand where you are coming from. I found that feed was important as well ! The sweet spot for me seems to be around 350 rpm and 40 - 50 mm a minute at 15 to 20 thou DOC in steel. Cast iron is about half that feed rate at about 20 - 25 mm. A carbide insert fares much better ( a carbide parting insert in place of the HSS )
but it makes bloody hot chips.Best Regards:
13th Oct 2020, 09:10 AM #13
I just went looking for a photo from late last year when I machined my larger cast iron bandsaw bed, but can't seem to find it.
I know I sent some to Peter (Bollie) showing him the wear and the finished job.
I never got any step between passes using my 75mm facemill, I could see the pattern, but couldn't feel it. From memory I had to do 4 passes. As for depth I was trying to take as little as possible off, I think I ended up a little over 1mm.Using Tapatalk
13th Oct 2020, 09:19 AM #14
Found them
Using Tapatalk
13th Oct 2020, 09:20 AM #15
Another one
Using Tapatalk
Cleaning Cast iron surfaces : Mill Table & Lathe Ways
By steamingbill in forum METALWORK GENERALReplies: 10Last Post: 4th Dec 2019, 07:16 PM -
WTB-Cast Small Cast Iron Lapping Plate
By Betnorm in forum WANTED TO BUYReplies: 4Last Post: 19th Nov 2019, 01:01 PM -
Cast iron fireplace - Question for restoring using Penetrol & Liberon Iron Paste
By mookschank in forum METALWORK GENERALReplies: 8Last Post: 19th Jun 2013, 06:32 PM -
Cast iron VS Cast steel lathe compound slide
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 23rd Dec 2012, 11:40 PM -
Riser Block for Mill out of Cast Iron Hollow Bar - where to get the Bar?
By markjaffa in forum METALWORK GENERALReplies: 50Last Post: 8th Aug 2010, 07:51 PM
