Results 16 to 18 of 18
13th Oct 2020, 01:14 PM #16Most Valued Member
- 4,890
Thank you Dave, at present I am just roughing with cuts varying between.5 to 2.5 or slightly more with the 80 face mill,I have noticed after about 40 passes over 105 mm width at the above depths of cut I need to rotate the tips.
I am able to achieve no significant/ noticeable step after rotating the tips, main question was in regards to anyone using a 100 mm face mill of the KM12 style..
Was just curious, to see what others may of achieved or noticed, I have noticed that as the tips wear the residual heat in the job increases, ( new tips virtually produce no noticeable retained heat no matter the depth of cut).
Most if not all finish passes will be taken at .5mm or less.
13th Oct 2020, 05:15 PM #17
I'm pretty sure mine is a CTC face mill
Using Tapatalk
15th Oct 2020, 07:40 AM #18
Cleaning Cast iron surfaces : Mill Table & Lathe Ways
By steamingbill in forum METALWORK GENERALReplies: 10Last Post: 4th Dec 2019, 07:16 PM -
WTB-Cast Small Cast Iron Lapping Plate
By Betnorm in forum WANTED TO BUYReplies: 4Last Post: 19th Nov 2019, 01:01 PM -
Cast iron fireplace - Question for restoring using Penetrol & Liberon Iron Paste
By mookschank in forum METALWORK GENERALReplies: 8Last Post: 19th Jun 2013, 06:32 PM -
Cast iron VS Cast steel lathe compound slide
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 23rd Dec 2012, 11:40 PM -
Riser Block for Mill out of Cast Iron Hollow Bar - where to get the Bar?
By markjaffa in forum METALWORK GENERALReplies: 50Last Post: 8th Aug 2010, 07:51 PM
