Results 1 to 13 of 13
Thread: Edison Phonograph Thread
10th Oct 2020, 04:27 PM #1Golden Member
- Apr 2009
- Kingswood
- 930
A good friend collects old sound producing play boxes and has several Edison style phonographs.
Where possible, the boxes are brought back into operational status, and it is fascinating when he demonstrates a horizontal wax cylinder.
The task he has asked me to do is screw a small holder of some sort into a larger 'thinga-ma-jingy'.
Perhaps it is the holder for the pick into the end of the trumpet.
The photo shows the two items.
The thread is a puzzle.
It is about 0.060" diameter.
It has been compared to a UNC 0/80 tap, specified as 0.060", but it is finer.
Tried a ISO 1.4/0.3 tap, about 86 tpi, but it is finer than that also.
Cannot see into the hole well enough to see if its threaded.
Edison was a cunning businessman, perhaps he used a proprietary thread.
Any suggestions ?
Keep well,
John.
10th Oct 2020, 06:17 PM #2Philomath in training
Have you tried BA threads? They were used on instruments all over. After that as you suggest, you are looking at 'specials'
10th Oct 2020, 07:03 PM #3Golden Member
- Cairns, Q
- 666
If it is not a special thread used by the manufacturer I would hazard a guess that it might be a Thury thread. This was a Swiss thread widely
used in the late 19th century/early 20th century mainly by clock makers and instrument makers. The phonograph application would be similar to these.The BA series of threads are derived from these Thury threads and should be interchangeable.
British Association Screw Threads | BA Thread Chart | Apollo International
It looks as though an 11BA thread might fit your description. BA dies are still available, but 11BA is fairly uncommon. Two old stock ones left here though @ $19 each.
https://www.minibearings.com.au/stor...dbt015b/?v=943
Frank.
Michael posted while I was typing this.
10th Oct 2020, 07:29 PM #4Golden Member
- Apr 2009
- Kingswood
- 930
Michael,
Thanks for the comments.
BA thread is unlikely considering it is Edison in the US, possibly predating the introduction of BA threads (1903 in the UK).
11 BA is 0.059 " dia and 81.9 tpi, so not a match.
12 BA is 90.9 tpi, but only 0.051", so also not a match.
I will try and sort out just where the small holder was acquired, then hope I can get a specification/description/guide as to what it is.
I live in hope that if I can penetrate the phonograph collectors cadre, I can define the thread,
The hole will let a 1 mm drill through, but not a 1.1 mm, so tapping to the screw thread is an option (if I can get a tap for that size).
Keep well,
John
franco posted while I was typing.
11th Oct 2020, 01:31 AM #5China
- Dec 2005
- South Australia
- 1,658
If you are talking 1mm, you may find this would suit, https://www.mektronics.com.au/bernst...1-pieces.htmlI have no Idea where you would buy separate taps, I use these and sometimes one like this for jewellery Makinghttps://www.jewellerssupplies.com.au/product/26907-thread-cutting-screwplate-set-0-8-2-0mm
11th Oct 2020, 04:04 PM #6Most Valued Member
11th Oct 2020, 10:20 PM #7Senior Member
- May 2015
- Richmond
- 214
11th Oct 2020, 10:44 PM #8Gear expert in training
- 34
- 1,080
12th Oct 2020, 09:43 AM #9Senior Member
- May 2015
- Richmond
- 214
12th Oct 2020, 02:46 PM #10Golden Member
- Apr 2009
- Kingswood
- 930
OldRustyToolie,
Thanks, I might take you up on the optical comparator, a good excuse to get some of the locals to a lunch.
Got onto my friend, who told me we are dealing with a "Reproducer" and gluing is not an option.
The screw must be removed to fit a gasket (of some kind).
The screw is one of a number acquired from the US several years ago, source now lost.
He is a member of a forum and will make inquiries.
Checked the screw against a 12 BA screw.
About 6 pitches of the unknown = 5 pitches of the 12 BA.
So, pitch is about (90.9) X 6/5 = 109 tpi.
Keep well,
John.
12th Oct 2020, 10:34 PM #11Senior Member
- May 2015
- Richmond
- 214
13th Oct 2020, 06:58 PM #12Golden Member
- Apr 2009
- Kingswood
- 930
I think I have identified the thread.
Horological Waltham #1 is 0.059 " and 110 tpi.
Now to find a tap.
Keep well,
John.
13th Oct 2020, 08:01 PM #13Gear expert in training
- 34
- 1,080
AHAHAHAHA
Seriously though, good luck; I reckon you'll either have to make one or have one made, if you're lucky a watchmaker might have one. Do you know the angle?
As a side note, it would seem that Waltham threads are specified in metric diameter and imperial pitch for some reason https://pocketwatchdatabase.com/guid...olof-ohlson/92
17 tpi thread
By azzrock in forum THE HERCUS AREAReplies: 24Last Post: 27th Aug 2020, 02:43 PM -
why cant I cut this thread?
By Alf Scotting in forum METALWORK GENERALReplies: 47Last Post: 27th Oct 2018, 12:53 AM -
16 TPI thread
By BigStick in forum METALWORK GENERALReplies: 9Last Post: 3rd Dec 2015, 04:42 AM -
This Thread Could Be About You!!!
By sydneyfc in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 28th Oct 2007, 09:39 PM
