Results 1 to 7 of 7
    Jul 2011
    Adelaide
    837
    Default Vertex dividing head BS0 Spindle nose and Hercus not the same?
    I have just taken possession of a Vertex BS0 dividing head. It is supposed to be a 1½" x 8 Threads per inch spindle nose. It measures at 1½" x 8 t but my 3 Hercus 1½" x 8 backplates won't even make a full revolution before they get stuck. I don't believe I would be the first to have this problem since both bits of kit are so common in this country. I have two machines that these 3 chucks fit on so am somewhat surprised they don't fit the Vertex dividing head.
    In fact the chuck that came with the DH will fit both the other machines. In an ideal world I would like all my chucks to be interchangeable so getting the DH's hardened shaft thread ground to suit the others seems my only choice. But before I do, does anybody know what is going on here?
    Aug 2006
    1,105
    I think the Hercus is 1-1/2" x 8 USS thread whilst the Vertex is 1-1/2" x 8 BSW
    Jul 2011
    Adelaide
    837
    Quote Originally Posted by Com_VC View Post
    So 55 degree vs 60 degree thread angle? That would make sense and should mean grinding it will work. I did use a pitch gauge with 60 degree form to measure, but I can't be sure that it isn't 55 degrees. Thanks for the thought.
    Jul 2016
    35
    1,522
    That would be my bet, another thing may be the thread crest/root radius. There will be an almost fully rounded root on the Whitworth threads.
    The BSx heads from Asia seem to vary in details a fair bit. Especially some have morse tapers, some brown and sharpe and I've even seen a Jarno. I wouldnt be surprised if spindle threads were the same.
    Jul 2011
    Adelaide
    837
    I have examined the threads much more closely. I believe they are both 60 degree thread angle and 8 TPI. I am however sure that the pitch circle of the DH thread is larger than that of the Hercus Nose. I note also that the register on the Vertex is 0.015" oversize.
    Jun 2011
    Australia east coast
    2,713
    Quote Originally Posted by lamestllama View Post
    Yeah went through this 30+ years ago. It's oversize for a Hercus standard spindle nose, you just need to machine the backplate to suit. Not much of a job really, I made 3 back in the day out of cast iron offcuts.
    PITA factor is the chucks don't really interchange if you've a Hercus lathe as the thread is sloppy and the register is a different diameter.
    Could be worse - my heavy K&T DH has a Cat 50 taper only. Now that is a pain to make tooling for.
    PDW
    Jul 2011
    Adelaide
    837
    PDW
    PDW,
    Thanks for confirming this is a known problem.
    I am going to go the other direction and make the spindle match my other spindles (Hercus T&C grinder workhead and a Precision Grinding UNIMAC). It will be a once off annoyance.
    Worst outcome is I will have to make a new spindle if I screw up. But even that would have the upside of replacing the B&S #7 taper with a MT2.
    PDW
    That would be a lot worse. With my equipment I have a good chance of fixing this spindle, I would have no chance of making Cat 50 tooling.
    Eric
  1. hercus mill dividing head plates
    By hpa1 in forum THE HERCUS AREA
    Last Post: 18th Jun 2019, 10:26 AM
  2. Vertex Dividing Head
    By Col2310 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 6th Mar 2019, 01:42 PM
  3. Hercus dividing head for milling machine
    By wm460 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 23rd Nov 2016, 07:37 PM
  4. Hercus Dividing Head runout
    By Pete F in forum THE HERCUS AREA
    Last Post: 16th May 2011, 12:47 PM
  5. Hercus Dividing Head
    Last Post: 3rd Jan 2011, 09:20 PM
