Results 1 to 1 of 1
19th Sep 2020, 01:34 PM #1Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Setup for grinding small annular cutters.
SAM_0709.jpgSAM_0710.jpgSAM_0711.jpgHello again.
Small cutters are hard to regrind. With little space between the flutes the wheel has to be dressed up fresh with the diamond only advanced a thou each pass to preserve the wheel edge. I use an edge angle of 15 deg each side to make it easier and if necessary adjust the index finger to just above center height. This morning there are a dozen cutters to do so I'm starting with the smallest and working up in size.
regards
BC
Annular cutter grinding
By steamloco1954 in forum METALWORK GENERALReplies: 9Last Post: 17th Aug 2020, 01:54 PM -
Annular cutter grinding info
By steamloco1954 in forum METALWORK PROJECTSReplies: 5Last Post: 22nd Jan 2020, 08:36 AM -
Annular cutters and arbors
By rodm in forum METALWORK - Machinery, Equipment, MARKETReplies: 6Last Post: 6th Jan 2019, 11:10 AM -
Where to find small gear cutters
By Michael G in forum METALWORK GENERALReplies: 3Last Post: 28th Sep 2016, 03:39 PM -
VICTORIA WOODRUFF cutters small. laverton
By azzrock in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 15th Nov 2011, 10:04 PM
