Results 1 to 14 of 14
19th Sep 2020, 09:22 AM #1Golden Member
- Aug 2015
- Melbourne, Australia
- 843
Local supplier of 4 point t handle socket wrenches?
Hi all, anybody know of a local supplier of the above? These guys:
Many thanks,
Greg.
19th Sep 2020, 10:25 AM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
Timely thread, I’m looking for a couple of imperial sizes.
19th Sep 2020, 12:22 PM #3Most Valued Member
- Healesville
- 2,129
There are some on ebay, search "lathe toolpost spanner"
19th Sep 2020, 01:10 PM #4Golden Member
- Aug 2015
- 843
Thanks shed. I didn't think of the 'toolpost' keyword for searching. Doh.
Though, ebay on that search or some similar ones are not really showing up the t handle type. Just one in the UK. Wrong size though. At least that is what it shows me!
Hare and forbes has some metric ones, but the 12mm might be just a bit wobbly for 7/16" square nut.
19th Sep 2020, 03:31 PM #5Most Valued Member
- 5,945
Greg and others, if you get really stuck for one, you could make your own by Rotary Broaching. Here's a link to You Tube for How To Do It
https://www.youtube.com/results?sear...ching+on+lathe
HTH
19th Sep 2020, 04:06 PM #6Most Valued Member
- Mar 2011
- 1,536
A more versatile approach that means only grinding one HSS tool would be to drill the round hole and remove most of the material, then use a 1/4” HSS tool ground as a broach to cut the corners square using the quill of the mill as a press (could probably also use a drill press with some careful setup) Slow and no doubt tedious but way cheaper than a rotary broach setup. Joe Pi did a really good how to on it on YouTube that for the life of me I can’t find at the moment.
In the mean time, until I can be bothered either making or buying some, I’m just using 12pt sockets.
19th Sep 2020, 05:55 PM #7Golden Member
- Aug 2015
- 843
Kryn, tadpole, thanks. Specifically, I was wanting to avoid making something. I'm already like 7 layers of inception away from the thing I'm actually doing, like, fixing something that is to help make something to help test the accuracy of a thing I'm making to hold another thing that I'm making to help make a tool. That helps me makes stuff.
I like the 12 point idea. Cool. 👍
19th Sep 2020, 06:07 PM #8Philomath in training
- 6,542
Adam, what sizes are you looking for? I have a 1/4" square broach and could do a small barrel for you if you are chasing that size; there are other cheats if the use is not going to be high torque
19th Sep 2020, 09:03 PM #9Most Valued Member
- Mar 2011
- 1,536
I’ll PM you on that Michael.
Greg, could you replace the fasteners with cap screws and use a hex drive instead?
19th Sep 2020, 10:32 PM #10Most Valued Member
- Healesville
- 2,129
Ha.....i think we all do that....make things to make things to make things...
A quick way to make a square socket is to bury an end mill into the end of length of rod, centered on 2 sides and the bottom, then run the end mill over the top at the height of the top of the square, prep and weld on a bit of plate to close the top then turn it to
the finished dia that you want.........boil the jug while you are doing it then you can have a cuppa...
20th Sep 2020, 02:06 AM #11Senior Member
- Aug 2007
- 292
Are you open to sockets with 8 points (also called double square)? A "T" handle and extension would complete the ensemble. There are also 4 point sockets but I can't find examples except for impact type.
https://www.ebay.com/itm/Genius-Tool...sAAOSwE95aU8Eg
https://www.amazon.com.au/Williams-W...A5Q4883BTEDATT
Pete
20th Sep 2020, 03:39 PM #12Golden Member
- Aug 2015
- 843
shed, nice technique. Thanks. Easy way also to get a square hole in a boring bar.
tadpole, I guess I could replace them with caps screws, but, the machine is 80 years old next year and it still have those original bolts in fairly good nick, so, keep to keen them.
Pete, I've not heard to the double square thing. Thanks.
Funny you know, I thought it'd be simple to find once I figured what they were called. But .. nope! The mcmaster carr one for 7/16" is like $45 USD - that is quite some AUD coin once you get it landed n all.
Thanks all, if I do find some, I'll post here.
25th Sep 2020, 09:37 PM #13Senior Member
- Feb 2014
- Werribee, Melbourne
- 177
Does the application have to a tube spanner or could it be a flat type square drive ?
This is a 7/16" square spanner to suit an old Lock tool holder I picked up that I use for the tailstock on the Senecca - is it only 7/16" that you are after BTW?
26th Sep 2020, 09:54 AM #14Golden Member
- Aug 2015
- 843
Hi Ray, I was after the t handle type is it is for the taper attachment and clamp for the lathe. Things get a little cramped there.
There is no emergency though. I have a small spanner I use that does the job. Actually, it was kind of a "hey, wouldn't the proper tool be nice to use instead of a spanner" moment. I thought they'd be out there but I just didn't have the right search terms. Seems not!
old whitworth sidchrome socket set ,plus old sidchrome socket bar
By robyn2839 in forum METALWORK - Machinery, Equipment, MARKETReplies: 9Last Post: 10th Jun 2019, 09:06 AM -
Local supplier of one-shot lube parts?
By StrayAlien in forum METALWORK GENERALReplies: 15Last Post: 15th May 2018, 11:34 PM -
Local Agricultural show
By DSEL74 in forum METALWORK GENERALReplies: 7Last Post: 21st Nov 2017, 08:01 AM -
Beer Wrenches
By DSEL74 in forum THE SMITHYReplies: 10Last Post: 22nd Jul 2017, 12:51 AM -
Local 303 stainless supplier?
By PDW in forum METALWORK GENERALReplies: 5Last Post: 2nd Sep 2015, 08:44 PM
