Results 91 to 93 of 93
21st Nov 2020, 08:38 PM #91
Hi Steve, Guys,
If both 110 volt solenoids are intended to be activated at the same time, wire the coils in series for 220/240 volts.Best Regards:
21st Nov 2020, 09:04 PM #92Most Valued Member
- 2,666
Workshop press build - hydraulic questions
I'm assuming they are rated to run continuously, but will keep an eye on them.
Thanks John - great idea and I hadn't thought about doing that.
Unfortunately it turns out I need 3 solenoids turned on.
As well as #12 and #14 I also need #5
Its all very temporary connected "proof of concept" for now - but its working!!
21st Nov 2020, 09:16 PM #93
Hi Steve, Have you got a spare one ! It could be used to solve the voltage issue. Two in series in parallel.
Hercus hacksaw hydraulic lifter - oil and other questions
By StrayAlien in forum METALWORK GENERALReplies: 33Last Post: 18th Nov 2022, 08:10 PM -
40T Hydraulic Press
By scottyd in forum METALWORK PROJECTSReplies: 19Last Post: 24th May 2022, 10:49 PM -
Need to build a workshop, share your experience
By caskwarrior in forum METALWORK GENERALReplies: 36Last Post: 28th Jul 2019, 11:51 PM -
Excavator hydraulic thumb build
By asheddie in forum METALWORK PROJECTSReplies: 6Last Post: 3rd Nov 2016, 04:23 PM -
Hydraulic Press Jigs
By Oldneweng in forum METALWORK GENERALReplies: 4Last Post: 1st Jul 2012, 09:25 PM
