Results 31 to 39 of 39
Thread: Looking for solution to problem
14th Sep 2020, 09:35 AM #31Golden Member
- Apr 2018
- Drouin Vic
- 635
I just threw this to my wife who is an occupational therapist (OT) and now works for dept of health, has some knowledge of NDIS etc. She recommends that you ask the NDIS people to approve an occupational therapist assessment. NDIS won't approve anything without professional assessment first. Then get an OT to assess your needs. There are OTs who specialize in driving modifications and NDIS should be able to refer you to someone appropriate. The OT then makes the assessment and can then recommend exactly what you need and make a report to NDIS. NDIS will then determine if they are going to fund it. No way they will fund or approve something that you come up with in person- hence the blank looks you have got. If you go through the appropriate channels you should have access to all the right people and gear. If you decide to DIY you are on your own; also I think you would face real problems with insurance if anything happens down the track, so to speak.
14th Sep 2020, 11:12 PM #32Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Thanks Pete,
That makes sense. I will look into it.
Had a couple of replies today.
One of Droogs links is a no go. PE Racing? Their Modules need their own ECU in order to calibrate it.
Found out the mob who assist elderly people don't do vehicle mods in their Bunbury office....doh. I thought the Mens Shed being right next door was a give away....lol
10th Nov 2020, 04:46 PM #33Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Some more info, but not much progress.....
The NDIS approved company that does pedal conversions 'can't help me' after they inspected my car. No reason given, even when asked.
He did say my conversion was illegal ( which is ISN'T) as it was done in 2010. The new rules say the car must have BOTH pedals fitted these days, so if I change it, it must comply.
I request from NDIS for them to recomend a supplied has gone unanswered so far.
A different supplier in Perth was going to get me a quote, but nothing......
A English company who make a installation for a later Audi model WON'T sell it to me as it has to be installed by licenced....blah, blah, blah.....
I found out my car uses a 'Pedal Box' that all the pedals are mounted to. The newer models have a different part number but the part looks identical to mine.
Anyway, I bought a S/H one, with brake pedal and I'm going to seeif I can fabricate something myself and get it inspected. Not arrived yet.
All good fun, isn't it......
10th Nov 2020, 06:27 PM #34Most Valued Member
Thanks for the update, Steve.
Hope you get a satisfactory result. The Government certainly don't like to make life easy!!!!
16th Nov 2020, 10:46 PM #35Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I've just relaised I can upload pics to Google Photo's...doh, so I'll do that.
This the 'Pedal Box' I've bought so I can fab a pedal setup without laying upside down in the foot well.....
I hope its worth it....
https://photos.app.goo.gl/5h2A4fY85pvBTQqC9
26th Nov 2020, 10:44 PM #36Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
The pedal box arrived last week.
I screwed it down to a MDF off cut so I stays put while I ponder...
Have gone through several ideas in my head, but nothing has lept out at me as being 'the way to go'.
Its just ridiculous how hard its going to be. Very little room and very odd shapes to adapt to AND go around.
Lots of fabrication work as well. Not sure I'm up to it. Don't have the time.
Will keep going for now....Shouldn't cost too much to buy the parts I need to get an idea if its going to work, or not.
Buying some 12mm steel rod, 12mm universal joint, 2x clevis's and 2x 12mm rod ends.
Will have to 'dog leg' over the brake pedal as it is not legal to go under. Must not be any chance the brake pedal arm will come in contact.
I'll post some links to pics when I have something.
27th Nov 2020, 01:00 PM #37I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
Is it possible to utilise a bowden cable to get from one to the other? Might be a bit easier to thread the eye of the needle with one, perhaps with a linkage at the factory pedal to reverse direction so you don't have to S-bend the cable?
27th Nov 2020, 02:48 PM #38Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
27th Nov 2020, 04:17 PM #39China
- Dec 2005
- South Australia
- 1,658
Things have really gone to dog house, I used to work at the Crippled Children's Ass. many years ago , something like this would have been taken on board and a solution found and yes they did other work beside for the CCA.
now it seems they just all passing the buck.
My Tool Storage Solution
By Keith_W in forum METALWORK GENERALReplies: 13Last Post: 5th Mar 2016, 01:21 PM -
Is there a solution for joints pulling in
By Michael G in forum WELDINGReplies: 6Last Post: 9th Feb 2014, 01:47 PM -
Pivot hinges solution
By vicente in forum METALWORK GENERALReplies: 9Last Post: 16th Apr 2013, 11:08 AM -
Metal bluing solution
By ohno in forum METALWORK GENERALReplies: 28Last Post: 16th Dec 2006, 08:00 PM
