Results 1 to 15 of 39
Thread: Where to buy quality drill sets
3rd Sep 2020, 03:11 PM #1Senior Member
- Oct 2019
- Tasmania
- 53
- 149
I am sick of buying poor quality drill sets. I know poor man pays twice and in this case I have paid too many times, so its time to buy a decent set.
Can anyone point me in the direction of a quality metric drill set. Used for all types of metals, including stainless.
I am not that experienced in this but my limited knowledge would suggest a HSS with 5% cobalt??
3rd Sep 2020, 03:48 PM #2Most Valued Member
- 4,255
3rd Sep 2020, 04:40 PM #3Gear expert in training
- 34
- 1,075
Absolute steal here: $99 for a 25pc Guhring set https://generaltools.com.au/product/...ric-drill-set/
EDIT: more deals from the same place https://generaltools.com.au/product-...ng/drill-sets/
3rd Sep 2020, 05:16 PM #4Most Valued Member
- 4,255
Have to check them before you buy..
I recently took a set back for credit as the point on some over 10mm were not ground center of drill. A set of Vertex that I was going to acept as a replacement was same, so we did a credit card credit instead.
However my current set of Guhring that I purchased some years ago is beautiful.
Some poor sets must get pass QC.?
3rd Sep 2020, 05:42 PM #5Golden Member
- Jun 2005
- Helensburgh
- 618
Dormer, the price might be a bit up there but they won't disappoint you. I can't think of another brand that I would buy in preference. Amazon US have got some good brands as well all generally made in the US. https://www.amazon.com/s?k=drill+bit...f=nb_sb_noss_2
I have mostly Dormer and some of Chicago Latrobe and there is not much between them.CHRIS
3rd Sep 2020, 06:00 PM #6Gear expert in training
- 34
- 1,075
We use Guhring for standard drills at work (HSS and carbide), but we have some Walter-Titex parabolic flute drills as well which are suuuper nice.
3rd Sep 2020, 09:51 PM #7Most Valued Member
- 2,651
The different Sutton series aren't just more $$$ == higher quality either.
They have specific ranges for different materials and applications so look into what the intended use is for each set. I can't recall all the wanky names but from memory one of the sets that sounded good in the initial blurb was not recommended for heavier machine drilling in ferrous etc.
3rd Sep 2020, 11:56 PM #8Senior Member
- blackburn vic
- 297
Drill Sets
Just a suggestion.
Go to your local Bunnings and ask them to get a Suttons Drill Catalogue for you. When it arrives, have a read through and take your pick.
Roger
4th Sep 2020, 01:31 AM #9Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
We use Sutton Cobalt drill bits at work (purple packet) to drill all grades of inconel, Rene41, 13-8 stainless and 41xx steel in various states of hardness, by far the best we've tried, even when they dull and work harden the hole all they need is a lick on the grinder and it's back to business.
They would be my go to for stainless
4th Sep 2020, 10:23 AM #10Senior Member
- Oct 2019
- Tasmania
- 53
- 149
Thanks very much for the suggestions.
I am leaning towards the Sutton purple Cobalt set. At around $400 though its going to have to be a birthday or Xmas present....Ill have trouble convincing the rest of the household that I need a $400 set of drills. I am only a hobbiest after all
I would have spent more than that on drill sets over the years.
One thing that does annoy me a little though, is recently I had to drill several hundred holes in stainless for a job, so I bought a very expensive cobalt drill bit to do the job. Sure it was a nice bit but bugger me if I didn't break the thing after a few hundred holes.
Anyway, a week or two earlier I was at my old mums house doing a job and I forgot to take my drill set. So I popped down to the local bunnings and bought the cheapest hss set they had to complete the job at mums.
So after I broke the very expensive drill on this stainless job I figured I would sacrifice one of these cheap drill bits to try and complete the job. The cheap drill bit out performed the expensive drill and it is still going..........so I am a bit skeptical on paying a lot of money for drill bits.
4th Sep 2020, 10:35 AM #11Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Quality drills
Hello from BC.
I get asked for better drills for SS often. Most tradesmen don't operate the drills at a correct speed for the more difficult material. SS requires about 40 SFM drilling speed compared to 100SFM for mild steel. There are lots of speed charts on the net. Also with SS if you whack it hard with a big center punch your off to a bad start. You have started the work hardening process. Use a light hit on the punch or grind a pyramid shaped point on it.
Cutting oil plays a big part as well.
Most drills 4mm and over delivered today are wide web drills and have a notched, split point. Drill point thinning takes a bit of practice but get used to doing it. The drill manufactured won't change as it is a cheaper way to make them.
Standard HSS drills work well in SS if the speed is right. Sutton and Bordo are the brands I sell and surprisingly their cheaper sets are OK too. These are labelled P & N and Savage.
This year I have spent some time at 4 facet grinding. Both by hand and machine. It is a good alternative and not hard to master. You must have good tool rests and well cared for grinding wheels.
BC
4th Sep 2020, 10:53 AM #12Member: Blue and white apron brigade
- 7,182
For drilling in stuff like stainless bit survival can sometimes be be attributable to operator experience.
At the mens shed a member needed to drill 3 holes in a bit of stainless. After many minutes of trying with a regular HSS bit he failed to get through even one hole so he spoke to the supervisor who told him to push harder but to no avail.
Eventually the supervisor went to the sheds drill stash and took out a cobalt bit that I had bought in bulk from China.
The supervisor said "This should do it"!
Instead the member did this to the Co bit.
If you look really closely at the tip you will see a galled ball of metal.
Late that day the supervisor had a go at me for buying cheap drills from China so I brought a piece of the same SS and the bent drill bit and another new bit home.
I cut the tip off the bent bit and sharpened it.
Then I proceeded to drill holes in the SS with both bits.
I also drilled about another 20 holes in another piece of stainless with the damaged bit with no problems.
When I eventually spoke to said member and asked him what he was doing it turns out he was running the DP at to high high speed and pushing hard enough for the till to glow red hot. I figured he must have work hardened the start of the hole so after that nothing short of perhaps a carbide was going to cut it. Chances are the HSS would have been blunt.
4th Sep 2020, 11:25 AM #13Most Valued Member
4th Sep 2020, 04:14 PM #14Diamond Member
- Aug 2006
- 1,105
Wow, I've never seen a drill bit bent like that. Usually i just see them snapped. Is that because it was cobalt it was able to bend?
4th Sep 2020, 04:16 PM #15Gear expert in training
- 34
- 1,075
I suspect it was overheated to the point of going soft
Any opinions on JBS pedestal drill quality?
By WCD in forum METALWORK PROJECTSReplies: 10Last Post: 10th Sep 2020, 12:04 AM -
Saber split point drill sets
By eskimo in forum METALWORK GENERALReplies: 6Last Post: 19th May 2018, 01:34 PM -
Tap and die sets.....tap magic
By jw2170 in forum METALWORK GENERALReplies: 32Last Post: 6th Sep 2013, 02:15 PM -
Chinese quality versus Swiss quality
By RayG in forum METALWORK GENERALReplies: 28Last Post: 5th Nov 2011, 12:41 PM -
Quality Drill Bits
By mat in forum METALWORK GENERALReplies: 10Last Post: 1st Feb 2006, 07:15 PM
