Results 16 to 30 of 33
  1. #16
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,514
    Got mine today and given it away already.
    Nev.
  2. #17
    Oct 2019
    Tasmania
    53
    150
    It would make a good block for a clamp or sissor knurl.
    Hmm yeh it would. I dont have a decent knurling tool yet, only one of those chinese ones that comes with a QCTP kit that you lean on the workpiece until you nearly snap the cross slide off.
  3. #18
    Dec 2013
    56
    1,418
    Quote Originally Posted by danshell View Post
    I made one many years ago with a weldment as machining 50x50mm square down was a waist and expensive.
    This block would be a good starting point for one. A clamp knurl or sissor knurl is far superior to a push knurl, as like you said it's hard on the crosslide.
    I took my quality knurling wheels out of of push knurl to use on my clamp knurl which works perfectly and no strain on the lathe.
    As I said I ended up with 5, so I'm trying to find other uses for these blocks.
    Hopefully others can think and suggest something to make out of them.
    Using Tapatalk
  4. #19
    Aug 2010
    Toorloo Arm, VIC
    39
    1,300
    Might make a good base for some form of ball turning attachment? Bore out where the bolts are, put a bush in for the pivot?
    Or maybe a holder for a big boring bar, rather than making up a special block to go direct on the QCTP?
    Machine a slot one side for holding a parting off tool, put an adjustable stop with a bearing on the end on the other side for parting off multiple pieces to the same length? Or similar idea, but with a turning tool for doing set length shoulders?
    Some kind of fancy indicator mounting plate?
    Probably suits all kinds of odd specific purposes, just depends on what type of things you do I guess.
    I guess at a pinch you could somehow wedge some emery paper in it and use it to polish stuff....
  5. #20
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by Jekyll and Hyde View Post
    I was just wondering if anyone had used one for its intended purpose yet. I haven’t because the shank is too large for my QCTP.
  6. #21
    Nov 2018
    Tasmania
    97
    I've seen a guy use it the other way around, rather than pushing the emery, he wrapped it around the shaft and pulled it with this tool
    Provides more than just 2 lines of contact that way
    and you still get the safety if that's what you are going for
  7. #22
    Aug 2010
    Toorloo Arm, VIC
    39
    1,300
    Quote Originally Posted by TommyGMachining View Post
    That's an annoyingly logical way to use it.... Now I'm wondering, if you just want to polish something, that seems like it'd be the best way, but if you're trying to hit a critical dimension, would it work better the 'other' way?
  8. #23
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    To apply pressure to emery on the lathe I've glued a thick (6mm) piece of felt to a block of wood. I'm able to apply more pressure and because the felt gives a bit, it will conform to the part a little better.
  9. #24
    Dec 2010
    Syd
    492
    Seems it might have come in use for someone quite recently, a motorsport identity in his 80s has just been caught up in a lathe, collarbone and shoulder smashed, ear detached. Impression I get, he was polishing a crank.
  10. #25
    Oct 2019
    Tasmania
    53
    150
    Quote Originally Posted by Hunch View Post
    Any idea who it was?
  11. #26
    Dec 2013
    56
    1,418
    Not good to hear a fellow machinist has been injured
    Using Tapatalk
  12. #27
    Nov 2018
    Tasmania
    97
    https://www.youtube.com/watch?v=mC2w...hnologyChannel
    Have a look at 13:20
    Yeah not sure if there would be a better way, at least you get more surface use this way around
  13. #28
    Jan 2016
    Wodonga Vic
    38
    633
    Quote Originally Posted by MasterSpoon View Post
    speaking of free stuff, well except a small postage charge for shipping outside the USA, CK Worldwide have created and are giving away the Ez-Dabr (Tig welder filler feeding tool), got an email saying they got heaps of people sign up so expect delays tho
    https://www.ckworldwide.com/ck-ez-dabr.html
    Well guess what turned up in the mail today, I had forgot I followed your link and filled out the form for a free wire feeder, I never actually thought I would receive one and I don't recall paying anything for shipping either
  14. #29
    Dec 2007
    103
    Quote Originally Posted by NedsHead View Post
    Same here!!
  15. #30
    Adelaide
    68
    1,374
    Quote Originally Posted by grunto View Post
    Same here!!
    Mine too.
  1. Free lathe
    By KBs PensNmore in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 6th Dec 2018, 12:26 PM
  2. Lathe safety (off topic prevention)
    Last Post: 20th Mar 2015, 05:28 AM
  3. Lathe Safety
    By Metal Head in forum METALWORK GENERAL
    Last Post: 17th May 2010, 12:55 AM
  4. colchester student 6 safety lathe
    By ARTHUR DE'ATHE in forum METALWORK GENERAL
    Last Post: 29th Apr 2007, 04:25 PM
