Results 16 to 30 of 33
Thread: Free Lathe Safety on Facebook
28th Sep 2020, 07:52 PM #16Most Valued Member
- 70
- 1,513
Got mine today and given it away already.
Nev.
28th Sep 2020, 08:31 PM #17Senior Member
- Oct 2019
- Tasmania
- 53
- 150
28th Sep 2020, 11:06 PM #18
I made one many years ago with a weldment as machining 50x50mm square down was a waist and expensive.
This block would be a good starting point for one. A clamp knurl or sissor knurl is far superior to a push knurl, as like you said it's hard on the crosslide.
I took my quality knurling wheels out of of push knurl to use on my clamp knurl which works perfectly and no strain on the lathe.
As I said I ended up with 5, so I'm trying to find other uses for these blocks.
Hopefully others can think and suggest something to make out of them.Using Tapatalk
29th Sep 2020, 04:16 AM #19I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,297
Might make a good base for some form of ball turning attachment? Bore out where the bolts are, put a bush in for the pivot?
Or maybe a holder for a big boring bar, rather than making up a special block to go direct on the QCTP?
Machine a slot one side for holding a parting off tool, put an adjustable stop with a bearing on the end on the other side for parting off multiple pieces to the same length? Or similar idea, but with a turning tool for doing set length shoulders?
Some kind of fancy indicator mounting plate?
Probably suits all kinds of odd specific purposes, just depends on what type of things you do I guess.
I guess at a pinch you could somehow wedge some emery paper in it and use it to polish stuff....
29th Sep 2020, 10:35 AM #20Most Valued Member
29th Sep 2020, 05:53 PM #21Member
- Nov 2018
- Tasmania
- 97
29th Sep 2020, 06:21 PM #22I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,297
29th Sep 2020, 07:28 PM #23Philomath in training
To apply pressure to emery on the lathe I've glued a thick (6mm) piece of felt to a block of wood. I'm able to apply more pressure and because the felt gives a bit, it will conform to the part a little better.
2nd Oct 2020, 09:02 PM #24Senior Member
- Dec 2010
- Syd
- 492
Seems it might have come in use for someone quite recently, a motorsport identity in his 80s has just been caught up in a lathe, collarbone and shoulder smashed, ear detached. Impression I get, he was polishing a crank.
2nd Oct 2020, 09:25 PM #25Senior Member
- Oct 2019
- Tasmania
- 53
- 150
2nd Oct 2020, 09:56 PM #26
Not good to hear a fellow machinist has been injured
Using Tapatalk
5th Oct 2020, 12:40 PM #27Member
- Nov 2018
- Tasmania
- 97
https://www.youtube.com/watch?v=mC2w...hnologyChannel
Have a look at 13:20
Yeah not sure if there would be a better way, at least you get more surface use this way around
18th Jan 2021, 01:59 PM #28Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Well guess what turned up in the mail today, I had forgot I followed your link and filled out the form for a free wire feeder, I never actually thought I would receive one and I don't recall paying anything for shipping either
21st Jan 2021, 04:39 PM #29Senior Member
- Dec 2007
- 103
21st Jan 2021, 08:34 PM #30
Free lathe
By KBs PensNmore in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 6th Dec 2018, 12:26 PM -
Lathe safety (off topic prevention)
By Michael G in forum METALWORK GENERALReplies: 49Last Post: 20th Mar 2015, 05:28 AM -
Lathe Safety
By Metal Head in forum METALWORK GENERALReplies: 15Last Post: 17th May 2010, 12:55 AM -
colchester student 6 safety lathe
By ARTHUR DE'ATHE in forum METALWORK GENERALReplies: 0Last Post: 29th Apr 2007, 04:25 PM
