Results 1 to 15 of 20
Thread: reticulating compressed air
31st Aug 2020, 05:07 PM #1Most Valued Member
Gents,
My little 6.5 CFM Clisby compressor lives on the other side of a wall in my workshop. I'd like to reticulate the air to three points in the shop.
1. At the lathe for blowing swarf off QCTP holders before returning them to the drawer, and for feeding my mist cooler,
2. At one side of the shop for my spray gun,
3. At the other side of the shop for plugging in a hose for filling car/motorbike tyres.
I found this kit https://sydneytools.com.au/product/c...SABEgI3hPD_BwE
For the price, I doubt the fittings are top notch. But are they good enough for my purposes? Or am I better off buying individual parts? If so, any suggestions where to get air pipe & fittings in Melbourne?
PS. I have 5.4m of 3/4" copper pipe, which isn't enough to do the job. But would it make a good initial run to cool the air and condense out any water?Chris
31st Aug 2020, 05:48 PM #2Most Valued Member
- 2,671
Given the current restrictions etc I’d say that’s not a bad way to go.
Getting a kit saves a lot of rooting around chasing parts.
Doesn’t sound like you’re needing big volumes of air, so I wouldn’t bother with adding copper line for cooler etc to start with as most of the moisture will condense out in the compressor tank.
Steve.
31st Aug 2020, 08:49 PM #3Member: Blue and white apron brigade
Kit looks pretty good but I would not hard connect any of the end point devices. Instead I would terminate using quick-fit air fitting and then use some flexible hose between the terminal point an the devices so you will be up for a bit more than the kit . I really recommend the Nitto Hi-Cupla series fittings (Blackwoods have them) - they cost a bit more than the SCA budget fittings but they will last a lot longer and are easier to use.
I'd still be putting a low point near the end of the Spray line and insert a drain tap. at this point.
A Copper pipe won't do that much but can't hurt so I would use that too.
31st Aug 2020, 09:38 PM #4Most Valued Member
31st Aug 2020, 09:50 PM #5Member: Blue and white apron brigade
31st Aug 2020, 09:53 PM #6
31st Aug 2020, 09:55 PM #7Most Valued Member
31st Aug 2020, 10:07 PM #8Most Valued Member
Thanks gents. They offer free shipping over $99, so I think I just found my next project.
31st Aug 2020, 11:06 PM #9Most Valued Member
- 2,671
For outlet fittings I absolutely agree with BobL. Don’t buy cheap they are crap.
I’ve been really happy with these Nitto style “Sumake” brand ones. Not sure where I got these ones from (possibly Totaltools) but they work well.
Just push the male fitting in and they automatically lock. Push the collar back again and they spit the male out.
Coincidentally I’ve been bitching quietly to myself lately every time I used my hose reel connector as it had a very nice looking brass Nitto style fitting but it was almost a 3 handed operation. Hold the collar back, push in the fitting and then hold it there while the collar came back. Finally swapped with a Sumake one on my air receiver that hardly ever gets disconnected. Bliss.......
You can get them on eBay for around $40 for 5 so reasonably priced I reckon.
1st Sep 2020, 10:10 PM #10Most Valued Member
- Sep 2010
- Lebrina
- 1,915
I'm not so sure. Given that Jack is running a small compressor with presumably a smallish receiver and also uses the air for spray painting it will mean that the compressor will be spending a fair percentage of it's time pumping and relatively little resting (cooling) time while spraying. I reckon any improvement to the condensing ability of the reticulated circuit would be a good investment.
1st Sep 2020, 10:31 PM #11Most Valued Member
- 2,671
Thanks - I actually missed the spray gun bit and only registered the duster and inflation requirements.
If there’s painting involved then obviously more air required and anything to help remove moisture is worthwhile.
1st Sep 2020, 10:43 PM #12Most Valued Member
Thanks. My compressor pretty much runs continuously when I’m spray painting.
2nd Sep 2020, 10:02 AM #13Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,553
To quote a sticker I saw on a plumbers van once many years ago.. Do it proper, use copper
2nd Sep 2020, 11:32 PM #14Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
Chris, thanks for that link. The cheapest kit I had found was nearly double the price: https://rapidairsystems.com.au/produ...me-garage-kit/
Note that these guys also offer extra parts for expanding your kit,
and kits based around 3/4" pipe: https://rapidairsystems.com.au/produ...ne-master-kit/
I have been thinking about installing something like that for a while. The experts all say a large main pipe, maybe in a loop, and then smaller piped that drop down to your tool outlets. But, being cheap, I was tossing up an extra tank (a receiver) with small pipes, instead of large bore pipes.
P.S. This is a typical setup. The blocks are screwed onto your walls as a solid base for your quick connect sockets:
3rd Sep 2020, 09:15 AM #15Most Valued Member
Humidity measurements in compressed air
By BobL in forum ELECTRICALSReplies: 35Last Post: 4th Jul 2020, 10:19 PM -
Vertical tank for compressed air
By nadroj in forum WANTED TO BUYReplies: 15Last Post: 18th Nov 2019, 08:47 PM -
Nylon Compressed Air tube
By glivo in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 2nd Jul 2018, 09:41 AM -
Compressed air for swarf/chip clean up
By jack620 in forum METALWORK GENERALReplies: 34Last Post: 6th Aug 2017, 04:30 PM -
compressed aiir powered grease gun
By BobL in forum METALWORK GENERALReplies: 5Last Post: 21st May 2015, 02:02 AM
