Results 1 to 9 of 9
31st Aug 2020, 01:36 PM #1Most Valued Member
- 2,671
Tapered pipe threads - are the sockets usually tapered too?
Probably a really dumb question, but I've had a look online but can't get any clarity on what is standard practice.
I need to make a female socket that will have a 3/4" BSPT fitting or plug screwed into it.
The nipple is tapered, but are the female threads usually tapered too? Info online says they can be either, and the only female fitting I've got here to check is a ball valve (which is parallel).
Its only an oil drain plug so either way will seal OK, just interested as to what is considered to be "standard"...
31st Aug 2020, 01:40 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
All my pipe taps are tapered, and would make tapered holes. A tapered hole would hopefully increase the sealing area a bit.
31st Aug 2020, 03:16 PM #3Senior Member
- Nov 2019
- Brisbane
- 69
- 452
BSP fittings
Hello Steve.
BSPP and BSPT fittings should not be mixed as the few threads that engage may strip before sealing. The parallel type are used for hydraulic or other high pressure fluid. The sealing is by way of an O ring, under the hex. BSPT fittings are designed to seal on the threads. There is some info on how many threads of a BSPT tap should protrude when full threading is complete on the web. If your making a socket you will have to grip it well.
BC
31st Aug 2020, 03:58 PM #4Member: Blue and white apron brigade
31st Aug 2020, 04:04 PM #5Most Valued Member
You have to wonder about the wisdom of designing two pipe standards that shouldn't be mixed, but are able to be.
31st Aug 2020, 04:45 PM #6Most Valued Member
- 2,671
31st Aug 2020, 05:10 PM #7
All the pipe taps that I have are tapered ones ! A couple of very old dies are too !Best Regards:
1st Sep 2020, 04:06 PM #8China
- Dec 2005
- South Australia
- 1,657
According to my Plumbers father ( also a plumber ) the female and the male thread a both tapered
1st Sep 2020, 04:39 PM #9Most Valued Member
- 4,258
Not in all cases
They also use parrallel...but again one meeds to check refrigeration always use taper.
Thats how I have had so much trouble with refrig mechs going to the likes of Reece Plumbing...who also sell refrigeration products...mechs dont specify and counter staff dont know the customer wanted refrigeration fittings.
Need a lump of 2x4 to make some mechs understand tho.
Tapered Gibs !
By BaronJ in forum METALWORK GENERALReplies: 14Last Post: 13th Jun 2019, 06:55 PM -
Tapered BSP threads.
By RayG in forum METALWORK GENERALReplies: 19Last Post: 16th Jun 2015, 09:03 PM -
1:20 Tapered reamer
By Ueee in forum METALWORK GENERALReplies: 6Last Post: 16th May 2013, 11:53 AM -
Tapered Gib Adjustment
By Anorak Bob in forum METALWORK GENERALReplies: 8Last Post: 14th Nov 2011, 08:21 PM -
5/8 tapered pin reamer
By azzrock in forum THE HERCUS AREAReplies: 11Last Post: 18th Nov 2010, 08:03 PM
