Results 1 to 12 of 12
Thread: Machinery Transport Adelaide
28th Aug 2020, 12:06 PM #1Golden Member
- Apr 2019
- 589
Dont think I have asked this before.....
I need to move 3 machines from Cavan to Aldgate - 1,000kg, 2,700kg and 3,200kg.
Any Adelaidians know of good removalist companies? I just got a verbal quote of $2,200!!!!!!!!!!!! The last mob I tried to use dropped a mill off the forklift.
Most likely need a forklift capable of the 3,200kg and preferably one that fits under a 2280mm roller door. Will be hard with a truck mounted crane as those generally do not have the ability to point downwards and get into the roller door.
Thoughts?
28th Aug 2020, 12:25 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
In my experience as soo as anything other than just a truck crane gets involved it starts to get very very expensive
28th Aug 2020, 01:23 PM #3Member
- Oct 2012
- Mullaloo WA
- 80
I have used GKR Transport twice for moving milling machines. The machine is forklifted onto a Hiab truck, truck goes to where it is needed, the Hiab crane lifts it off the truck and pallet jacks are used to move the equipment where needed. A pallet jack usually has a capacity of 2500kg, no problem with using two of them. So for the price of the shire of a Hiab truck and two pallet jacks your problem could be solved.
28th Aug 2020, 01:53 PM #4Golden Member
- Jun 2005
- Helensburgh
- 618
Brick trucks usually have all terrain forklifts with very experienced operators just make sure that each machine is chained to the forklift especially top heavy machines such as mills, band saws etc so they can't fall off.
CHRIS
28th Aug 2020, 03:23 PM #5China
- Dec 2005
- South Australia
- 1,656
A mate used this company about a year ago all went well
https://www.tomastransport.com.au/
28th Aug 2020, 06:24 PM #6Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
$2200 is reasonable. 3200kg is a big lift for mobile equipment.
You can try Nicks Cranes or Fork’nCranes but both will be around if not more than your existing quote.
28th Aug 2020, 08:49 PM #7Most Valued Member
- 5,945
Trent Buddle has shifted a few things for us, mainly Guilos and Brake press. He's based in Murray Bridge and has several trucks and a Franna Crane to help move machinery, and basically will go anywhere.
Hours: Open 24 hours Phone: 0432 318 965
28th Aug 2020, 08:54 PM #8Senior Member
- Sep 2009
- Newcastle
- 341
Will you get more options if you can skate the machines out so the roller door is not an issue?
28th Aug 2020, 08:55 PM #9Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
Fork n cranes shifted my planer, was very happy with the service.
28th Aug 2020, 09:19 PM #10Golden Member
- Apr 2019
- 589
31st Aug 2020, 07:20 PM #11Most Valued Member
- Australia east coast
- 2,713
[QUOTE=racingtadpole;1973724]$2200 is reasonable. 3200kg is a big lift for mobile equipment./QUOTE]
It cost me less than that to get an 8 tonne 12m long steel sailboat moved from shed to marina!
Ditto for moving an 8.5 tonne tracked loader over 360 km.
PDW
31st Aug 2020, 08:24 PM #12Most Valued Member
- Mar 2011
- 1,536
Different equipment in a different state under different circumstances, seems logical there would be a different pricing structure.
My folder, guillotine and slip roller came from Brisbane to Adelaide on standard size pallets and cost about $160 each in transport. I sent a small round column mill to Townsville from Adelaide on a standard size pallet, partially disassembled so the cubic dimensions were as small as possible and it cost $700.
re: The Adelaide to Wadonga Transport Post
By Grahame Collins in forum GENERAL DISCUSSION / OFF TOPICReplies: 0Last Post: 30th Nov 2017, 06:47 AM -
Interstate Transport (Adelaide to Wodonga)
By NedsHead in forum METALWORK - Machinery, Equipment, MARKETReplies: 7Last Post: 27th Nov 2017, 07:47 PM -
Transport 2 x 1.5kw 3ph motors from Adelaide to Melbourne
By StrayAlien in forum MEMBERS TRANSPORTReplies: 1Last Post: 24th Oct 2016, 08:02 AM -
Redwood Machinery - Adelaide
By Gavin Newman in forum METALWORK GENERALReplies: 15Last Post: 3rd Feb 2015, 05:02 PM -
Transport avail - Adelaide/Horsham
By Bryan in forum METALWORK GENERALReplies: 0Last Post: 18th Jun 2013, 09:35 AM
