Results 1 to 15 of 17
24th Aug 2020, 04:45 PM #1Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
Kant Twist and Pivot clamps - EOI in a group buy on parts
So...
Because I don't have enough on my plate already..
There's been a couple of threads here recently on making Kant Twist style clamps the end result of which was it wasn't economically viable to make them yourself in onsies and twosies. This coupled with the recent 'group buy' of some material stock here in Adelaide got me thinking..
If there is sufficient interest to make it worth the effort I would be willing to have the primary flat parts of some Kant Twist style clamps and some Pivot style milling clamps laser cut using my trade account, which carries a minimum $200 order.
I'm sort of thinking 80/150mm for the Kant twist style sides, and 80/150mm for the pivot clamps. In both instances you would receive the flat sheet metal parts only, you would be responsible for the hardware, spacers, contact points and threaded components.
I haven't had it quoted as yet, but I would imagine the larger clamps pivot clamps for example would be in the vicinity of $6-7 per piece (2 pieces required for a clamp). I would probably specify minimum order of parts to make two of the same size clamps.
If you are interested, post here, and if sufficient over say the next fortnight we'll go from there and work out finer details.
So I don't run foul of any forum rules, this is not a commercial venture, any parts supplied would be at my cost price plus outgoings such as packing material and postage passed on at cost also.
If this does get off the ground it will be strictly cash in advance to secure a place on the cutting list.
For those that possibly aren't familiar with these types of clamps, links below
Kant Twist
https://www.artisansupplies.com.au/w...ist-Clamps.png
Pivots
https://www.youtube.com/watch?v=D5sbvkpsf6w
24th Aug 2020, 07:06 PM #2
Hi Adam,
There is always my thread on kant clamps along with drawings and design information.
https://metalworkforums.com/f65/t200...ht=Kant+ClampsBest Regards:
24th Aug 2020, 07:54 PM #3Most Valued Member
- Mar 2011
- 1,554
Thanks, I’d not seen that thread previously, very useful.
25th Aug 2020, 09:46 AM #4Member
- Apr 2015
- Tungkillo, South Australia
- 87
- 74
I am interested in joining a group buy of Kant side plates.
Charles
25th Aug 2020, 11:24 AM #5Most Valued Member
- 4,258
Damn, another project...count me in for say 6 or so depending on costs/sizes etc
25th Aug 2020, 02:55 PM #6Member
- Nov 2015
- Brisbane Australia
- 85
I would also be interested
I am interested in making 4 of the 150mm clamps
25th Aug 2020, 07:31 PM #7
Hi Racingtadpole
Put me down for parts for 4 sets of Kant clamp plates please ,dependent on price and size.
2off x 80
2off x 150
25th Aug 2020, 08:13 PM #8Senior Member
- Apr 2013
- Toowoomba Qld
- 401
I'm interested in some of both. Pending final design & pricing.
Have been meaning to design and make some Kant Twist clamps for a few years now but haven't got around to it. My main concern would be pricing, I have a local laser cutter which were fairly well priced last time I checked and thinking it's possible that although you might get them cut cheaper, the shipping cost would remove any savings.
26th Aug 2020, 08:55 AM #9Most Valued Member
- Mar 2011
- 1,554
So there’s probably enough interest at this point to start heading down the path of generating models for quoting.
Would everyone that’s expressed interest so far, please edit your post with the size(s) you’d like.
26th Aug 2020, 10:25 AM #10Member
- Apr 2015
- 87
- 74
26th Aug 2020, 06:32 PM #11Most Valued Member
- 4,258
Some 80's and 150's...say 4 of each?
Cant have too many clamps they tell me.
Cant edut previous reply.
26th Aug 2020, 06:47 PM #12Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Count me in.
4 sets of 80's and 4 sets of 150's. (Kant twist clamps)
Ken (Toggy)Last edited by Toggy; 27th Aug 2020 at 08:42 AM. Reason: Clamp style added
26th Aug 2020, 07:53 PM #13Diamond Member
- Aug 2006
- 1,106
Hi, I would be interested in both styles in both sizes.
2x 80mm Kant Twist
2x 150mm Kant Twist
2x 80mm Pivot Clamps
2x 150mm Pivot Clamps
26th Aug 2020, 08:57 PM #14Member
- Oct 2012
- Mullaloo WA
- 80
Kant twist clamps
2 of each 80mm and 150mm please.
Col
26th Aug 2020, 10:50 PM #15Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
I'll take, 2 of each 80mm and 150mm please, depending price.
Tks John
KANT-TWIST Round Handle Clamp 3/4", Clamp Mfg 396
By DSEL74 in forum METALWORK GENERALReplies: 7Last Post: 10th Aug 2019, 08:05 AM -
Kant Twist Clamps and Forge and Foundry Burners on Gameco's Web Store
By Corin in forum ANNOUNCEMENTSReplies: 1Last Post: 10th Nov 2015, 12:07 PM -
Kant Twist Clamps on the shelf in Australia
By Corin in forum ANNOUNCEMENTSReplies: 0Last Post: 25th Aug 2015, 07:54 PM -
Pivot spring replacement
By blinger in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 31st Dec 2014, 05:19 PM -
Group or link all Group Buys into a sub-forum such as Member Deals
By Bitslong in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 24th Jun 2009, 12:10 AM
