Results 1 to 9 of 9
Thread: AL-250G Lathe - Ball Oilers
23rd Aug 2020, 07:13 PM #1New Member
- Feb 2019
- Kyabram, Victoria, Australia
- 7
Some of the ball oilers on my lathe are damaged. The ball sits below the upper seat and they don't do their job of sealing out crud. These oilers were clearly the result of unskilled installation. Just what you get with a cheap Chinese machine.
I measured the oilers as best as I could in-situ, and they seemed to be 6mm. This made sense given that it is a metric machine, so I ordered some from Ebay and they arrived in due course.
Ok. Time to start replacing the damaged ones. Start with the one in the cross slide hand wheel extension housing. (What else would I call it?)
I prised it out and discovered that the side had been sheared off during installation.
Ok. Now insert the new one. What?? It doesn't even look close to fitting. What size did MrEbay send me? Check with the micrometer, 6mm. Ok, that's what I ordered. Check the size of the hole with digital calipers, 5.75mm dia or thereabouts. Just about midway between a #1 and #2 drill size. Standard chopstick???
I decided to ream out the hole with a 6mm H7 reamer, cleaned out the crud then gently tapped the new oiler into place. Perfect fit!!
I proceeded to replace 4 more oilers. There are others that will need replacing, but they will need to wait. Cleaning out the crud after reaming the holes requires various amounts of disassembly.
Does anyone out there have any idea as to the wierd size of the original oilers? All of the ones I replaced were the same size.
23rd Aug 2020, 08:46 PM #2Most Valued Member
Sorry can't help you with the Ball Oiler sizes, but your pics didn't come out.
Suggest that you use the Forums insertion of pics.
23rd Aug 2020, 09:04 PM #3
I can't see any pictures either
Using Tapatalk
23rd Aug 2020, 09:56 PM #4New Member
- Feb 2019
- 7
Strange about the pics not showing. Ok on my PC and also via my phone.
I'll try via insert.
DbNdyY5kvp05jM_ZOj9DY4OyW-TWcdXZFYOA9gKLlgTZkHXPa_2htelshy7Wi0YMuz_YweLJ0YQ__9hb5tmxXSX2wxE9rQBW.jpg
x1aop5pIKYFdTY-JxpWDXeEe8qUouMvh810frRmizUktQN2z8RiZ0OYQbUrvLAGFWIQgODhNhEIhbsD_FCuKhiAsmLXKRFv_.jpg
Not too sure about the quality of these inserted pics. How do they look at your end Kryn?
23rd Aug 2020, 10:11 PM #5New Member
- Feb 2019
- 7
Thanks for the heads up about the pics, Kryn & Dave.
I just tried inserting the pics into a reply but the reply seems to have vanished into cyberspace.
Here goes again.
Did these pics come through ok?
23rd Aug 2020, 10:27 PM #6
Yep came through, good job.
Those oiler's sell for so much from local tool places, but as I found you can buy 20 for $3 from AliExpress, and they wonder why we don't buy local. There all coming out of China.
Yours where a strange size though, I haven't run into any problems like that, there either 6, 8 or 10mm.
One thing I did buy that maybe useful to you as well, is the 90 degree oil cups with the little flip lids sold on eBay and ali, these are for the tailstock end to oil the leadscrew, feed rod and forward reverse shaft on my 12x36 lathe.
Ball oiler's seem stupid in that area, where a cup you can just add a few drops and even put a bit of material in them to slow it down to a drip to keep them oiled as they only run on cast iron.Using Tapatalk
24th Aug 2020, 06:00 PM #7Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
Ball Oilers
Looks like you could possible by swaging over the end of a spent 22 case (or larger) with a spring and ball bearing inside.
I'd try it but still working on getting the shed set up since moving house.
John
24th Aug 2020, 06:37 PM #8New Member
- Feb 2019
- 7
Dave. I like your idea of an oil cup for the lead screw.
Mine has a larger size ball oiler. Looks about 8mm so I measured it. 7.5mm or thereabouts.
Maybe they make these lathes full size then shrink them by some wierd factor.
24th Aug 2020, 10:08 PM #9
AL-250G Lathe - Threading Indicator Table
By Fatfettler in forum METALWORK GENERALReplies: 8Last Post: 15th Jul 2020, 05:13 PM -
Lathe Oilers
By Woodyo in forum METALWORK GENERALReplies: 5Last Post: 15th Feb 2018, 08:31 AM -
Removing Ball Oilers.
By wm460 in forum METALWORK GENERALReplies: 14Last Post: 22nd Jul 2015, 10:15 AM -
Ball bearing oilers
By Jim Ferrous in forum METALWORK GENERALReplies: 14Last Post: 17th Sep 2013, 06:56 AM -
Replacement ball valve oilers/oil hole covers
By markjaffa in forum METALWORK GENERALReplies: 11Last Post: 2nd Nov 2009, 12:31 AM
